Page 373 of 1057 FirstFirst ... 371372373374375 ... LastLast
Results 3,721 to 3,730 of 10566
  1. #3721
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Installed a new Sony XAV-601BT head unit in the Troll and ordered a new Hiflo 3" cat from the crew at Genie
    Sent from my iPhone using Motorculture mobile app
    www.swat4x4.com
  2. The Following User Says Thank You to oncedisturbed For This Useful Post:
    Stropp (24th May 2014)
  3. #3722
    Just went out to the shed and started mine up..poor thing should be on blocks,only did 26km in the last month....was thinking about taking it for a drive but it's raining..
  4. #3723
    put new plates on mrs possums car this week,to match mine.
  5. The Following User Says Thank You to Avo For This Useful Post:
    Clunk (24th May 2014)
  6. #3724
    177 Post(s)
    I was gonna jump in mine and take it for a spin, tinker with boost control a bit more and possibly head over to Mudskis, but walked out looked at it and walked back inside.
    .......... TPC's Avatar
    63 Post(s)
    Quote Originally Posted by wa 489 View Post
    Don't GQ's work in the rain?
  8. The Following User Says Thank You to TPC For This Useful Post:
    Avo (25th May 2014)
  9. #3726
    yeah but no point getting it wet if your not going to get it dirty...
  10. #3727
    Legendary Alitis007's Avatar
    15 Post(s)
    As far as codes and lights, nothing comes up, as I constantly monitor it on scangauge. The only code there is the EGR code (blocked). And also no lights. Once again, if it is a mechanical issue, such as the pump, injectors and/or the turbo, it's still very bizzare, why sometimes it gives me all the power in the world.
    Maybe start a thread asking if someone will lend you their ecu?? But like i said i'm not sure if its plug and play or if you will need to sync the ecu with the bcm and nats system. When i get a chance mate i'll let you know and we'll have a looksee
  11. The Following User Says Thank You to Alitis007 For This Useful Post:
    Hodge (25th May 2014)
  12. #3728
    Advanced thebrod's Avatar
    Sep 2013
    Pulled the window tint off the front window. The guy that I bought the Patrol off thought that it looked cool (yep, he was right!), and its great while driving during the day, but totally illegal and a big P.I.T.A. at night.
    Was actually bracing myself for a whole world of pain getting it off, but it came off really easy and didnt leave any glue behind. Only took about 45mins all up.
    Method used was :
    1. spray entire window with windex (make sure that its the one that says not to use on window tint!)
    2. cover entire window with a large black plastic garbage bad to keep the windex from evaporating and get some free heat from the sun
    3. park in the sun and leave for 30mins.
    It is actually quite wintery here today so I gave it a bit of help from a heat gun on the outside of the window
    4. peel back slowly from one corner, dont pull too fast or jerk it or you'll leave glue behind
    5. drink a beer to celebrate a job well done!!!!
  13. The Following 3 Users Say Thank You to thebrod For This Useful Post:
    Clunk (25th May 2014), Parksy (26th May 2014), Stropp (25th May 2014)
  14. #3729
    177 Post(s)
    Many thanks to Mudski! Took the car around to his place and he tampered with the needle valve and we both took it for a spin and shes back to normal now. Very happy jan! Lets just see how long it stays this way ...
  15. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    Alitis007 (26th May 2014), mudski (25th May 2014)
  16. #3730
    177 Post(s)
    Quote Originally Posted by Alitis007 View Post
    Thanks George. After Mudski played around with it today, it's leaning towards the boost control side of things as the culprit. So will keep an eye out on it and see if it shovels s*** in my face again. Hopefully not.
