Page 372 of 1057 FirstFirst ... 370371372373374 ... LastLast
Results 3,711 to 3,720 of 10566
  1. #3711
    Thanks George!
    I don't know anybody with the same year and manual that I can compare the pair with. I spent a while, not long ago looking over connections that are at reach. I didn't pull much apart but yeah, as far as everything i got my hands onto it seemed good. But you have the right idea, as it does seem like something electrical. In saying that though few weeks back in Tallarook, if it was to show that sort of symptom it would have been then as the car copped a good shake over. But that day it too, it had all the power in the world. Might to more analyzing over the weekend, and play with the boost control for the 389284th time, just in case it is something like that.
    Wind your needle valve in a tad more Eric....
  2. #3712
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    mark you don't think the ball bearing might be sticking
  3. The Following User Says Thank You to Sir Roofy For This Useful Post:
    Hodge (24th May 2014)
  4. #3713
    It's not limp mode is it?
  5. The Following User Says Thank You to Winnie For This Useful Post:
  6. #3714
    Quote Originally Posted by roofy View Post
    If it was he wouldn't get his max boost at all...
    Nah mate limp mode you can't drive at all until you let off the go pedal and back on again.
  8. #3715
    Patrol Guru cgm's Avatar
    Jul 2012
    Ballarat
    Wow...car feels brand new again!!!
    Spent a small a fortune but I am ready for the trip. The boys at Patrolapart did a great job. Even little niggly things like fixing up AB's DIY wiring...lol
    Hope they gave you a discount with all the free advertising they got out of you this week.
    Thanks, Cameron
    No Patrol now - Just good memories!
  9. The Following User Says Thank You to cgm For This Useful Post:
    AB (24th May 2014)
  10. #3716
    Quote Originally Posted by cgm View Post
    He probably swapped the work for some redback rooftop bags lol
  11. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    Avo (24th May 2014), Stropp (24th May 2014)
  12. #3717
    Legendary Alitis007's Avatar
    15 Post(s)
    Thanks George! I don't know anybody with the same year and manual that I can compare the pair with. I spent a while, not long ago looking over connections that are at reach. I didn't pull much apart but yeah, as far as everything i got my hands onto it seemed good. But you have the right idea, as it does seem like something electrical. In saying that though few weeks back in Tallarook, if it was to show that sort of symptom it would have been then as the car copped a good shake over. But that day it too, it had all the power in the world. Might to more analyzing over the weekend, and play with the boost control for the 389284th time, just in case it is something like that.
    Then thing with electrics is when they get hot they sometimes make a good connection till they get cold again, same as when a globe blows and you tap the lens and it works again untill you turn the light off and the filament breaks contact. The other problem is that you should have a fault code flash up if it was a sensor but i said to try another ecu ( don't go and buy 1 see if we can find another to borrow) in case there is a fault with it for some reason and thats causing all the dramas.
    If all the sensors, wiring and all the other electrical components are ok the only other things left are the injector pump, injectors and turbo i would think
  13. The Following User Says Thank You to Alitis007 For This Useful Post:
  14. #3718
    177 Post(s)
    Will try that again mate. At the moment It maxes boost around 2000-2500 revs, not sure if that is too slow or too fast.
    Nah definitely not limp mode. When she is in slug mode, the power loss is there way before boost even hits 12-14. Also releasing and re-applying throttle makes no difference.
    As far as codes and lights, nothing comes up, as I constantly monitor it on scangauge. The only code there is the EGR code (blocked). And also no lights.
    Once again, if it is a mechanical issue, such as the pump, injectors and/or the turbo, it's still very bizzare, why sometimes it gives me all the power in the world.
    WA Wheatbelt
    23 Post(s)
    Over the next few days, I'm gunna drive my Patrol over 700km - on the bitumen - again!! lol
    Time to hit the big smoke for some RnR.
  16. The Following 2 Users Say Thank You to DX grunt For This Useful Post:
    Clunk (24th May 2014), Stropp (24th May 2014)
  17. #3720
    Popping in are ya?
