Temp gauge needle starting to sort of flutter ever so slightly..sort of like slightly vibrating....had to look at it closely to make sure I was seeing what I was seeing so it was only slight
then it became more erratic after a couple of hours where it was fluctuating about 3mm each way...eventually seemed to bounce and then just stayed right down the bottom as though the needle had just come off...but it hadn't and stayed there...checked all connections at sender etc ...all seemed good...now today it is working again and sitting just above the half way mark...previously it was sitting just below the half way mark before the fluctuations....no fluctuations now
When I did the head , the one thing I didn't replace was the temp sender ...I don't know why ?..I did every thing else !
The return pipe under the radiator cap to the overflow bottle is crimped about half way as I posted in a previous thread...I will eventually be putting a dedicated temp gauge in but in the mean time..would this be electrical , ? the sender ? or a possible a conscequence of the crimped return line ?....
From start of fluctuation to it ending up at the bottom and staying there was travelling over about 300klm constant....cheers
