Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: WTB simple roll cage GU Patrol
    Nov 2013
    QLD
    Hi everyone, I am planning a big lap and I am thinking about some simple roll-over protection around Brisbane. Does anybody has any suggestions? Or know a small business that might be able to help out?
    To be honest mate I would bother.
    The work required to but one in is bugga all and the patrols handle roll overs quite well.
    Evils mate had a double roll over a few weeks back, was damaged, but drivable..
    I'll find some pics
    From a double roll over
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    92GQ (14th May 2014)
    Nov 2013
    QLD
    cheers for sharing mate! That looks surprisingly mild, I expected much worse!
    Quote Originally Posted by dannypatrol View Post
    I know hay.
    I would be looking at a good step / slider setup and scrub bars.
    Looks like roof rack took most the pain aswell.
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    wow ive seen a gq on its roof on the streets and it was way worse then that gu. So bad so the front of the roof was probably half the normal height
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
    I think that GU was bloody Lucky! I have seen the A pillar crushed down.
    If your keen the. I would keep a lookout for a ROPS out of a mine spec GU mate. You will pick it up for under $500 and it will bolts straight in. Should be plenty about in QLD?
    Nov 2013
    QLD
    cheers, I have a search out at gumtree and ebay but so far only found one for only the cargo area or landcruiser 100 which I dont think will fit. But i am not in a rush so will wait patiently. Havent found out how it would fit half way (so between the doors) and how easy it is to fit, any knowledge on this?
  10. #9
    Id say the roof rack played a big part of holding the Patrol together,
    but a lot of "ifs"
    You could give Brown Davis a buzz and talk to Kevin about their ROPS
  11. #10
    Nov 2013
    QLD
    but a lot of "ifs"
    Good point on the roof rack. I have heard of Brown Davis stuff before. Point is that I will have my car for the big lap only so I am looking for a cheap solution. Obviously, safety is priceless but with all the other involved costs, a high end product as from Brown Davis is a bit out of reach.
