Page 32 of 50 FirstFirst ... 3031323334 ... LastLast
Results 311 to 320 of 498
Thread: Outback Ideas Recovery points
  1. #311
    3rogs this thread and Squalos questions have migrated over from P4x4. All he is asking you to do is show case your product. No answer is the wrong answer mate
  2. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Alitis007 (11th May 2014), threedogs (11th May 2014)
  3. #312
    I make the "Bush Hoop" using a M20 eye bolt that is fully welded to a laser cut piece of 12mm x 250 grade mild steel with a 20,5 hole cut in the centre to a piece of 50x50x3 RHS.
    Its assembled using a 20MM spring washer and HT nut sometimes I use a Nyloc M20 nut. this is tightened using a rattle gun.
    Of the 1500 or so I have sold not one has failed in the field,
    Originally because these were so strong we, as in NATA and me put a SWL of 20,000LB on it but That exceeded the tow capacity of any 4wd on the market
    so I decided to reduce it to keep in line with other tow points . I then had it destruction tested and the 50x50x3mm RHS split where the pin goes in.
    I'll stand by this as a very strong rear recovery point. Most ppl use the billet and shackle or just the pin in the class 2 receiver. I'll dig out the tested one ond put a picture here.
    Of all the recovery points on the market I believe only mine are tested and made right here in Melbourne. I cannot vouch for any others at this stage.
    Edit Others that are made with the hook only use 1.5 -2mm rhs I have not made any for years now
  4. The Following 6 Users Say Thank You to threedogs For This Useful Post:
    Alitis007 (11th May 2014), Family4x4 (11th May 2014), Hodge (11th May 2014), menace 2 (11th May 2014), MudRunnerTD (11th May 2014), rusty_nail (11th May 2014)
  5. #313
    Patrol Guru Family4x4's Avatar
    Jan 2014
    Victoria
    http://www.nata.com.au/nata/
    for people who are unsure of who NATA is.
    In any moment of decision, the best thing you can do is the right thing, the next best thing is the wrong thing, and the worst thing you can do is nothing.
    Theodore Roosevelt
  6. The Following User Says Thank You to Family4x4 For This Useful Post:
  7. #314
    Expert Squalo's Avatar
    Sunshine Coast
    That sounds like a pretty secure arrangement to me. Thanks John.
    1995 GQ TD42 NA
  8. The Following 2 Users Say Thank You to Squalo For This Useful Post:
    growler2058 (11th May 2014), threedogs (15th May 2014)
  9. #315
    177 Post(s)
    I'll just say one thing here. Way before I bought a patrol, and way before I joined this forum and found out who John is and what he makes... When recovery points were talked about, Outback ideas are the only ones always recommended. I linger on a few other 4x4 forums and that name is the recovery point norm as far as I've seen.
    Even a big brand shop bloke swayed me from buying their ones and said mate forget all these, go straight to TJM and pick up a set of out back ideas points as they're the only ones properly tested on the market that he was aware of. So I listened.
  10. The Following 9 Users Say Thank You to Hodge For This Useful Post:
    Alitis007 (11th May 2014), Avo (11th May 2014), BigRAWesty (11th May 2014), Clunk (11th May 2014), Drewboyaus (16th May 2014), Family4x4 (11th May 2014), growler2058 (11th May 2014), Stropp (15th May 2014), threedogs (11th May 2014)
  11. #316
    Ok I've been toying with this for a few years , but now I'd like some input .
    As you can imagine its hard to make one front recovery point that will suit all model GU's and GQ's,
    with all the different bar/motor combo's available. The one pictured will fit every Patrol made,
    Yeah I hear you say, It bolts up to the shipping tie down point using one OE captive nut and drilling two more maybe
    12 mm holes . So it will have 3 bolts holding it, only downside is the size of shackle you can use. IMO this position would be fine, so any of your thoughts are welcome.
  12. #317
    My only thought is a lot of people will shy away because of the drilling.
  13. #318
    .......... TPC's Avatar
    63 Post(s)
    I agree, being a lazy bastard I would not want to have to drill holes.
    Already have mine though so I am happy.
  14. The Following User Says Thank You to TPC For This Useful Post:
  15. #319
    your not drilling the chassis as such , as I said only toying with the idea
    And by drilling and added two extra bolts it would make it very strong
  16. #320
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    could it not be longer to fit a larger shackle?
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
