Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: EGR Block & Provent finally done.
    Advanced NT09ST's Avatar
    Darwin
    Bit of an up date and maby an idea for others with the same problem.
    I was getting sick of draining the can by hand and making a mess so i made this set up and have tested it for a few mnts before posting it up on here.
    All the bits inc the hose came from Enzed so your local should be able to help.
    They only thing you may need to borrow is a nut sert kit, they are pretty expensive.
    The rest is just hose, a hose clamp, ball valve, 2 barbed fittings and 2 hose support clamps.
    The two holes are all rdy in the chassis rail but one needs opening up a tad to fit the nut sert.
    Its about 30 min work once you have the bits and then draining the can is a 10 sec job.
    09 ST CRD 5 spd Wagon, Snorkel, ARB Bar, Warn Winch, Duel Btys, Beaudesert 2.3/4 exh, Provent 200, Racor 445 ... now to find some money for the rest!
  2. The Following 2 Users Say Thank You to NT09ST For This Useful Post:
    Avo (28th April 2014), Beucam (26th May 2014)
  3. #12
    Apr 2014
    good idea with the valve and hoses neat to mate good job
  4. #13
    Advanced thebrod's Avatar
    Sep 2013
    Like it. Nice mod
  5. #14
    Expert Limmy's Avatar
    or purchase this hose kit . very good quality and fits perfectly
    http://www.ebay.com.au/itm/PROVENT-2...item3cb906c1dc
  6. #15
    476 Post(s)
    Very neat indeed. Well done. Blocking the EGR should take no longer that two stubbies mate. Which pipe did you end up blocking?
  7. #16
    Darwin
    The one closest to the front of the engine, i had some pics sent to me and found out that i had been sent the wrong blank plate so hence the confusion.
