Results 1 to 10 of 10
Thread: Oil Catch Can
    Patrol Guru ova50's Avatar
    Nov 2011
    Syd, Northern Beaches
    Oil Catch Can
    I have searching through the forum and the net about the oil catch cans and what the differences between them are.
    I am considering the Provent 200.
    A couple of things I am uncertain of, are:
    1. The existing hose from the rocker cover looks like it is about 5/8" internal Diameter. Is the Provent inlet and outlet the same size?. Cant seem to find any specific info on what size the inlet & outlet are on the unit.
    2. I was also looking at a previous post I found on this site, (a pdf file) and it mentioned that the restrictor was removed from the original hose and refitted to the new hose. Is this restrictor in all models or only some.
    Was a CRD
    All I've heard is that they are a good unit but hose sizes are different as you point out
  3. The Following User Says Thank You to threedogs For This Useful Post:
    ova50 (15th December 2013)
    Patrol God Stropp's Avatar
    38 Post(s)
    yep great unit but the fittings are different sizes, all i did was take the provent and hose from the car to the hose shop and bought the hoses and bunnings for the clamps etc.
  5. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    muz muz (11th February 2014), ova50 (15th December 2013)
    Nov 2011
    Thanks for the pic"Stropp".
    The restrictor has me stumped. I found another earlier post while searching ( I think from a 2008 CRD) and mentioned his vehicle did not have this fitted in the original hose.
    Are the crds fitted with these.?
    Was a CRD
    Unafordable
    4 Post(s)
    Provent 200 has 25 mm entry (1") ZD30 hose is 16 mm (5/8"). You'll need reducers to go from 25 mm to 16 mm (1" to 5/8")
    You can piggy back on to original breather hose than extending it to Provent and than run new hose back to inlet pipe. On Di is as easy as flipping it over towards back of the firewall/bulkhead than using barbed joiner attach extension to Provent
    That way you don't need to worry about restrictor as you reusing original hose and no need to look for it.
  8. The Following 2 Users Say Thank You to Rumcajs For This Useful Post:
    muz muz (11th February 2014), ova50 (21st December 2013)
  9. #6
    Apr 2014
    Western filters sell a full kit for this
  10. #7
    Beginner Wang's Avatar
    Dec 2013
    Campbeltown / naw
    You can use a 6cyl falcon heater hose for a neat job with no joins. It has a flared end that will fit over the catch can
    http://www.rarespares.net.au/rarespa...product=CH1300
    2010 crd auto, snorkel, BFG ATs and nads underway
  11. #8
    Unafordable
    4 Post(s)
    Quote Originally Posted by Wang View Post
    There is one problem though, 6 cyl Ford Falcon heater hose is not oil resistant so be prepared to keep changing it at regular intervals, perhaps 6 months.
    Advanced thebrod's Avatar
    Sep 2013
    Hey Mate
    I have the provent 200 on my GU. Was fitted by the previous owner behind the bull bar. Has hose adapters as in the pic.
    Adam
  13. #10
    Jun 2014
    Newcastle NSW
    Thanks for the idea of mounting it behind the bull bar, it fitted in well
