Results 11 to 20 of 29
Thread: Chris Safari
    Expert chrisc2306's Avatar
    Feb 2014
    Wanaka, New Zealand
    Pictures don't really show much now its all black inside haha
  2. #12
    334 Post(s)
    What are teh seats out of Chris? they look great mate. Cumpfy?
  3. #13
    Feb 2014
    Wanaka, New Zealand
    I bought them brand new from a company in Auckland, they're just aftermarket buckets they are really comfy! They mounted pretty easily as well I had to pack up both the drivers and the passengers door side with 25mm square bar and just bolted the original bracket to the bottom of the seat and it worked perfectly
  4. #14
    Feb 2014
    Wanaka, New Zealand
    Got a bit more done on my day off today. Got the back seats back in place and wired up the keyless entry all the doors work from the button except the drivers which I'm just waiting on an actuator to sort that problem and then all will be sweet. Here's a couple more pictures of the interior now it's nearly finished
  5. #15
    Feb 2014
    Wanaka, New Zealand
    Well started stripping the paint off the truck to respray it. Man its tough sanding a whole day today and theres still so much to do! Doesn't help that there are so many coats of paint on it already seems never ending trying to get through it. Got a couple of dents to pull out and repair too before I do the respray
  6. The Following User Says Thank You to chrisc2306 For This Useful Post:
    Parksy (23rd April 2014)
  7. #16
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Stick with it Chris. I'm so sick to death of sanding! But the end result will be worth it. Will you be spraying it in a shed?
  8. #17
    Feb 2014
    Wanaka, New Zealand
    Quote Originally Posted by Parksy View Post
    Thanks mate I ordered an air sander to use with the compressor so hopefully that will improve things. I'm planning a weekend of sanding a repairing dents I reckon. Just had a look at your posts yours is looking good! I've got it under the car port at the moment and I'm not sure whether to spray it out there where there is more space or cram it into the garage, I'm going for the outside spray at the moment as long as it stays warm enough
  9. #18
    Jan 2013
    Nowra NSW
    5 Post(s)
    If you do it outside make sure you're going to have a warm night or paint first thing in the morning. Condensation will ruin your finish if it's still wet at night.
  10. #19
    Feb 2014
    Wanaka, New Zealand
    Thanks for the advice I'm definitely in need of some, this is my first time tackling a full respray. Do you know how much paint you ended up using respraying yours?
  11. #20
    Jan 2013
    Nowra NSW
    5 Post(s)
    4l should do you I think. I still have lots in the tin. I'll be doing small things tomorrow like the flares and fuel filler door, but this won't use much.
  12. The Following User Says Thank You to Parksy For This Useful Post:
    chrisc2306 (23rd April 2014)
