Results 1 to 10 of 16
Thread: No rear light
    Hardcore healy's Avatar
    south east melbourne victoria
    No rear light
    So my issue is I have no rear drive light on passenger side. I have brake light but no drive light they use the same globe wires are fine fuses are fine from what I can tell. Im not sure how or where to start on rectifying the problem any help much appreciated cheers
    IF ITS NOT BROKEN IT MUST BE A PATROL
    Have a look at the light itself..
    Mine use to snap or get rock hits at the housing itself..
    There solid mate no cracks hits etc. There Patroldocta ones im not sure if it could be the holder for the globe thats faulty cheers
    I've also had some issues with corrosion inside the globe holders..
    Play hell with the globes. I found a dremel sanding barrel fits perfectly down it..
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    healy (12th April 2014)
    They certainly are cheap looking holders guess ill have to crack it open as they look clean cheers
    They should just unscrew from the housing.
    sorry I was talking the globe holder yeah that twists out but im thinking now the wire is not contacting the globe
    All is clean
  10. #9
    Front left headlight is blown could this be causing the issue
  11. #10
    Does anyone know what power should be at brake and driving light?
