Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 76
Thread: New MUDMAP High Country App
  1. #61
    176 Post(s)
    This is how my Hema Explorer on Android worked for me on our trip. This photo is zoomed out a bit, shows the tracks we done (most of ). it also shows camp grouds, toilets, and many other things.
    Attachment 43201
    This is when I zoom in a little bit. Tracks become very detailed with names, elevation, etc... Clicking on each route we done shows time, elevation, average speed etc...
    Attachment 43202
    Then I can upload the track to hema cloud and show few more details like below.
    https://cloud.hemaexplorer.com.au/pu...0tyevc/Aerial/
    Here is a sample of high coutry walhalla area.
    Attachment 43203
    I had my laminated rooftops map with me, and the hema was much more detailed, like had more tracks etc...
    Attachment 43204
    The app is very fiddly so far as it is very new, some things are annoying etc... But it looks very promising.
  2. The Following User Says Thank You to Hodge For This Useful Post:
    MEGOMONSTER (12th April 2014)
  3. #62
    176 Post(s)
    Attachment 43201
    Attachment 43202
    Attachment 43203
    Attachment 43204
    Was just toying around with mates mudmaps, and his ones have nowhere near the detail hema has. Unless I'm doing something wrong?? Max zoom in, his Tallarook area shows roughly 50-60% of compared to the hema maps. Likewise with the rootop map I have. So far hema winning for me on all notes.
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Quote Originally Posted by MudMap View Post
    All our maps are compatible with all of our apps. So once you have purchased maps you can use them on any MUDMAP app. This is because we store your map purchases on a personal account which allows you to port any maps on the app of your choice. Mud Map is also compatible with rooftop.
    so I decided to try Mud Map 2 on the ipad, works quite well with the maps supplied though I haven't tried to purchase extra maps (maps supplied are quite limited for my use)
    I've downloaded the map converter and tried to run it but have been unable to convert any maps even rooftop maps (you will not that Mudmap claim that it works with rooftop maps)
    Looked up their web site problems page and its a common thread with people being unable to convert maps.
    would not recommend purchasing this app, there are easier ways to be frustrated that this!!
  5. #64
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    The mudmap convertor does work. The problem that occurs is the background permissions on the map you are trying to convert prevents them being converted to the mm format.
    I have both the hema apps and mm2 as well and switch between them to get a good level of coverage and take paper maps as well as a backup
    www.swat4x4.com
  6. #65
    I have MM2 but the converter does not work for me either, with Rooftops maps but they are maps I have made myself. I can't remember what file type they are but I will look tonight.
  7. #66
    Nov 2010
    6 Post(s)
    Quote Originally Posted by oncedisturbed View Post
    The issue is that maps that mm day will work don't work that's false advertising
  8. #67
    Feb 2012
    30 Post(s)
    There is a section on their site that states some types wont work but cant recall where it is
    www.swat4x4.com
  9. #68
    Nov 2010
    6 Post(s)
    Yep went through all that. got about 6 gig of ozi maps did a random selection with no success. By the time you get to the point of the help and problem files you've already purchased the program under somewhat false pretences!
  10. #69
    Nov 2010
    6 Post(s)
    Ok just to update progress
    I've used windows compatibility trouble shooter to fix the conversion app and it now converts files that are ozf2 and ozf3 but not ozf4,
    Some of the maps dont calibrate in the correct location when used on mud map and some are fine.
    Getting closer
  11. #70
    Oct 2011
    Essendon
    But still not as straight forward to use as Hema/MemoryMap by the sound of it....
    Sent from my iPhone using Forum Runner
