Results 1 to 8 of 8
Thread: Do GU 16 by 8" Wheels on a GQ Patrol Protrude Beyond the Flares?
    Nov 2013
    Gold Coast
    Hi All
    As per the header i'm considering replacing the 15" original wheels on the GQ with GU 16 by 8" original steel wheels; if I can find some; so I could have a greater range of tyres to chose from in future when I fit new ones.
    Talking tyres with a tyre salesman today and he tells me the GU wheel and tyre will protrude an inch or more beyond the GQ flares so be a tad illegal.
    Is he correct?
    As most of the GQs use is on road and towing I'm considering going H/T rather than A/T for a quieter ride. Any of you have experience with the tyres that are available, at this stage for 15" wheels?
    Yokahama Geolander H/T S G 051 is one option and Goodyear Wrangler HT is another. Another one is the the 31/10.5R15 HT AUSTONE CSR34
    Any thoughts on one or other of these? What else is there to look at?
    Thank in anticipation.
    Chimo
    Thomastown, Melbourne
    6 Post(s)
    Depends on the offset of the rim mate.... my -13 rims with 285 75 16 tyres did not go past the factory flares.
  3. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    Chimo (1st April 2014)
    As BA has said, depends on the offset. I have 15x8 rims shod with 33x12.50x15 tyres, so are approx 25mm wider than 285x75x16 tyres, my tyres protrude approx 10mm outside the factory flares on my tb42.
    I also have a TD42 with 16x8 CSA alloy rims originally from a GU shod with 285x75x16 tyres and they sit well within the factory flares. Different offset rims with different width tyres will make all the difference
  5. The Following User Says Thank You to Clunk For This Useful Post:
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    The factory wheels will be ok, but as Clunk and BA stated after market may be a different story with the offsets available
  7. The Following User Says Thank You to Dhuck For This Useful Post:
  8. #5
    Patrol Freak gaddy's Avatar
    redlands
    Chimo[/QUOTE]
    I'm on a set of kumo road venture's at the moment , and very happy so far 20 000 k nice and quiet on the road , great in the wet ,
  9. The Following User Says Thank You to gaddy For This Useful Post:
  10. #6
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    I'm running the gu wheels and they don't stick out at all. I'm fairly sure that they are a positive 10 offset. I'm keen to get rid of mine for the offset reason, I want something wider.
  11. #7
    Nov 2013
    Gold Coast
    Parksy
    What size are your wheels? PM sent
    Chimo
  12. #8
    334 Post(s)
    If you have Factory GU rims that you want to put on your GQ then they are all Pos10. and will not stick out at all mate.
    The boys above as talking about changing offsets and this can be a problem but your original question was about existing GU rims on a GQ and they will be no trouble.
  13. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Chimo (2nd April 2014), threedogs (2nd April 2014)
