Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: DEAD ZD30 to TD42T swap
    Mar 2014
    Unhappy DEAD ZD30 to TD42T swap
    Hey guys,
    Today my engine arrived for my TD42T swap, and turns out the supplier has kind of screwed me.
    After numerous phonecalls, I was promised that the engine had a "fully manual" injection pump. and the photos I was sent didn't give me a definitive yes/no.
    any ways turns out my TD42T is infact a TD42TDi.
    This leaves me with the question of what to do regarding the pump, the options i can think of are as follows;
    1. run it as is and not connect up TPS or Timing solenoid. and set timing to around .67 ($0) (is it possible to just strip the electrical components off the pump?)
    2. Exchange unit for a rebuilt boost compensated TD42T pump (around $1200-$1500)
    3. Source TD42TDi ECU & work that into my vehicle ($???, but heaps of extra work)
    I have tried searching, but cant find a solid answer.
    Feb 2011
    Shed
    45 Post(s)
  3. The Following User Says Thank You to growler2058 For This Useful Post:
    Dyl-SA (31st March 2014)
    North brissy
    Really........
  5. The Following User Says Thank You to nissannewby For This Useful Post:
    Really........
    Apparently lol
  7. The Following User Says Thank You to Clunk For This Useful Post:
    nissannewby (31st March 2014)
  8. #5
    Legendary happygu's Avatar
    Quote Originally Posted by Dyl-SA View Post
    Hey guys,
    I agree - it is much easier to go down the non-ECU controlled route ..... but you are in a bit of a bind ...
    I don't want to tell you how to suck eggs, but have you tried asking the Engine Supplier for the matching ECU out of the vehicle, since he supplied it, and the loom too although he would want payment for the loom I would think....
    As a second option, if it is too hard / costly, they should take the engine back too
  9. The Following User Says Thank You to happygu For This Useful Post:
  10. #6
    Mar 2014
    Engine was freighted Brisbane to Adelaide, and I'm happy with the engine, so returning it is not really an option.
    I will contact the vendor tomorrow, just to see what sort of response I get.
    Although looking at the diagrams, working the ECM into the ZD30 swap will be a complete nightmare.
    I think either a S/H pump, or finding a diesel specialist, preferably in Adelaide, that will exchange the TDi pump (maybe even throw them the old ZD30 pump as a sweetener) for the boost compensated manual pump is going to be the best solution.
  11. #7
    Fair enough too - once you have one in your hands, it is hard to let go.
    Lets hope it works out easier than it looks.....
  12. #8
    Feb 2011
    Shed
    45 Post(s)
    Apparently lol
    Apparently
    Sent from my iPhone using my thumb
  13. #9
    I thought a few of the guys recently bypassed the tps as it was failing??
    Is this an option here..
    Kustom Killa looms may have a plug and play loom.
    I believe they are located in Melbourne
  15. The Following User Says Thank You to threedogs For This Useful Post:
    Dyl-SA (1st April 2014)
