Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 12V plug in wagon
    Yeah, I pulled the bracket out that held the jack in place and replaced it with that, I figured the standard jack wasn't going to lift the car so it had to go. The amp install kit works well, it is the right length, it's fused at the battery, it's thick enough too and easy to fit.
  2. #12
    Advanced jaxt's Avatar
    Feb 2011
    Brissy
    mine's similar to molongmick but with a 6mm cable instead of 4mm.
    GQ TI 95
    - TB42EFI > LPG 90L, Ironman Snorkel, Ironman Awning, Rhino Roof Bars/Racks, 33"ATZ 4Ribs. Jensen DVD headunit, EFS Steering Damper, Castor Correction, Elinz DVD Headrests, Led lighting, Factory Diff Lock, 2" H/Duty Dobinson Coils and Ultima Shocks, GME 3220 UHF, Supercharge A/Round Main, CTEK DCDC to Aux Battery
  3. #13
    Expert 89GQ's Avatar
    Adelaide South Aus.
    I used 9mm Square with no voltage drop seperate runs to both pos and neg on the batt. Anderson Plug is for the fridge, Got rid of the ciggy plug on fridge lead.
    89 GQ TD 42
  4. #14
    Patrol Guru Airstrike's Avatar
    Feb 2011
    I am just worried about alternator or the battery as I only have 1 and cant fit a second
