Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Glow plug timer mod, what glow plugs?
    Expert Rickie3's Avatar
    Jan 2014
    Doing the glow plug timer mod on my 3 litre direct injection over the weekend, and want to do away with the the ceramic tip plugs, can someone advise the right metallic tip glow plugs I need to buy, preferably brand and part numbers please would be appreciative
    476 Post(s)
    Can't give ya parts numbers mate but Bosch and NGK are the two brands I would use...
    Rickie3 (27th March 2014)
    Jan 2014
    Surely someone on here has done this mod?, I need to know the correct glow plugs to buy
    Guess not.......
    Patrol Freak Wine_maker's Avatar
    Nov 2011
    Kazakhstan, Almaty.
    8 Post(s)
    Genuine Nissan glow plugs for RD28 is NGK. I think that Nissan use NGK for all engines when produce it.
    I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
    SHELLHARBOUR
    Hi Ricky3
    If you have a Direct Injection 3 ltr GU then it will not have glow plugs
    Glow plugs are only on indirect injection engines to get the 'recaro' pre combustion chamber hot enough to stop it quenching the heat of compression
    So no glow plugs for Direct injection as nothing to pre heat
    The 'Glow' light on Direct injection engines is illuminated whilst the engine ÉCU' goes through its pre start checks.
    so no timer involved and no glow plugs
    save your money for some thing else
    Regards
    Joe
    2010-DX Patrol Dual Cab Chassis, Front LOKKA, 3500kg GVM, 4.8 front brakes! (now stops like it should!), 4.625 Diffs (now drives like it should) 35"Mud tires, 3"exhaust, Rear air bags
    Jan 2014
    Quote Originally Posted by JoeG View Post
    Hi Ricky3
    Regards
    Joe
    ummmm now i'm confused, my 3L direct injection engine does have glow plugs, they are located under the intercooler I can see the bus bar running to them, and 4 rubber bungs at the top of them
    177 Post(s)
    Quote Originally Posted by Rickie3 View Post
    Are you sure you're not looking at the injectors?
    Jan 2013
    Glow plugs are not indirect injection only. They are in a variety of engines both direct and indirect.
    And yes in my brief scan ZD30s do have them.
  11. #10
    Jan 2014
    mines a 2000 3litre direct injection, i'm pretty sure injectors dont have a bus bar and a single hot wire large white with a red trace
