Results 1 to 5 of 5
Thread: Overfilling Engine Oil GU 2.8
    Beginner Rosscoe's Avatar
    Nov 2010
    Queensland
    Hi just bought a Patrol again a GU 2.8, I know all the stories about the 2.8 but have had one before and loved it. Checked everything before I paid and drove it home, checking the oil once the engine was cold and it has been overfilled (stupid me, I didnt redip the oil just checked that it was clean and had some in the sump lol, had been running before I got there), by a couple of litres i guess, can or will or has this now caused any damage to anything. Why would someone overfill the sump????????
    Thank you for reading.
    Rosscoe.
    Nov 2010
    Queensland
    Drained about 3 litres of oil, cleaned the MAF, cleaned the intercooler, blocked the EGR, fitted a water temp, boost, volt and an EGT gauge today just got to get the EGT sender fittted and hopefully she will be fine after the oil overfill.
    Feb 2011
    Shed
    45 Post(s)
    Geez that is a lot of extra oil! hopefully it hasn't stuffed any seals
    Nov 2010
    Queensland
    That is what I am hoping, had some oil around rear of rocker cover, have degreased it and will take it for a run tomorrow to see if she leaks again, now should be able to see where from if it does.
    Patrol Freak Wine_maker's Avatar
    Nov 2011
    Kazakhstan, Almaty.
    8 Post(s)
    Hi!
    Oil, around rear of rocker cover is not a problem of overfill. Its damn sore of this engine. I changed the rocker cover's seal 3 times with zero effect.
    I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
  6. The Following User Says Thank You to Wine_maker For This Useful Post:
    Rosscoe (23rd March 2014)
