Results 1 to 10 of 19
Thread: GQ windscreen wiper problems
    Advanced Matty852's Avatar
    Mar 2014
    Darwin, NT
    Hey guys, I have a 88 GQ I am trying to get back in the road but I can't seem to get the front windscreen wipers to work. I checked the fuse and that is ok and ran through the wiring and couldn't find a fault then went as far as pulling the motor apart and then trying another motor and that still didn't work
    Then I had a brilliant spark and realised I should've checked the relay before I went and pulled everything apart I can't find any info on what relay is for the front windscreen wipers, does anyone know which one it is???
    84 Post(s)
    The intermittent wiper amplifier is under the black cover in the engine bay, next to the battery. The unit is anchored to the wall and has a black, orange, purple, light green, brown/ white and brown wires to it. (Connector 144M)
  3. The Following User Says Thank You to mudnut For This Useful Post:
    Matty852 (14th March 2014)
    Mar 2014
    Darwin, NT
    Cheers mate, I will check it out once I'm back on my feet
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    The amp won't stop the wiper motor from working.
    With the ignition on, check that you have power in the Light Green wire at the wiper motor.
    The wiper switch switches earth. To check the operation of the switch disconnect the connector at the wiper motor. Connect the end of your test light onto the POSITIVE battery post.
    The test light should light up when you touch the Light Green with a Black trace with the wiper switch on low speed. On high speed it should light up on the Light Green with a Red trace.
    Have you checked that the wiper arm linkages aren't seized?
  6. The Following 2 Users Say Thank You to Yendor For This Useful Post:
    Matty852 (20th March 2014), mudnut (16th March 2014)
    Mar 2014
    Darwin, NT
    All the linkages are fine, I have gone as far as pulling out the old ones and replacing them with a new set, the plastic joint connecting it to the wiper motor arm was stuffed.
    84 Post(s)
    Well there you go. I learn something new every day on in this place. Onya Yendor.
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by Matty852 View Post
    No worries mate, have you check the wiring as detailed above?
  10. The Following User Says Thank You to Yendor For This Useful Post:
  11. #8
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Yeah the amp controls the intermittent wipers and the auto wiper sweep when the washers are used.
    If faulty it can cause the wipers to keep going all the time.
  12. The Following 2 Users Say Thank You to Yendor For This Useful Post:
    Matty852 (20th March 2014), mudnut (20th March 2014)
  13. #9
    Mar 2014
    Darwin, NT
    I checked the wires and it seems to be earthing out fine on the low and high settings
  14. #10
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    If you have power in the Light Green wire and earth is switch via the Light Green/Black and Light Green/Red when low and high speed are selected, you must have a faulty wiper motor.
    Try connecting you test light across the Light Green and Light Green/Black wires. Does the test light light up when on low speed?
    Also try bench testing your wiper motor by connecting positive and negative to the corresponding terminals in the wiper motor plug. Does the wiper motor work?
  15. The Following 2 Users Say Thank You to Yendor For This Useful Post:
    Matty852 (20th March 2014), mojo53 (4th September 2014)
