Page 12 of 57 FirstFirst ... 1011121314 ... LastLast
Results 111 to 120 of 565
Thread: Parksy's gq
  1. #111
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Don't have the head yet but made progress anyway. Removed the old valves and springs so I could re use the valve springs on the new head.
    Valve gear and rocker assembly removed
    The rocker assembly felt a bit graunchy when moving the arms so I pulled it all apart, gave it all a clean and gave the bores and friction surfaces a light sand with 600grit. Nice and smooth now.
    And the block all cleaned up. Used a scourer pad in the bores and removed most of the lines caused by the rings. I can barely feel the ridge now. It's got to be no more than a thou or two.
  2. The Following User Says Thank You to Parksy For This Useful Post:
    NissanGQ4.2 (19th March 2014)
  3. #112
    Thomastown, Melbourne
    6 Post(s)
    Did you order new head bolts.... I snapped one in the head re using old bolts... they are torque to yield so should not be used again.
    I am speaking from experience as I tried to use old ones and paid the price.
  4. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    Parksy (16th March 2014)
  5. #113
    Jan 2013
    Nowra NSW
    5 Post(s)
    Yep new bolts are on there way.
  6. The Following User Says Thank You to Parksy For This Useful Post:
    Bloodyaussie (16th March 2014)
  7. #114
    6 Post(s)
    Quote Originally Posted by Parksy View Post
    Cool you are cooking with gas mate!!!!!!!!!!!!!!!!!!!!
    The beast will be on the road before you know it.
  8. The Following User Says Thank You to Bloodyaussie For This Useful Post:
  9. #115
    Jan 2013
    Nowra NSW
    5 Post(s)
    Fingers crossed BA.... Fingers crossed....
  10. The Following User Says Thank You to Parksy For This Useful Post:
  11. #116
    Jan 2013
    Nowra NSW
    5 Post(s)
    New head and gear arrived.
    I noticed that the water passages in the head gasket are very small and actually blocked in some cases on some of the cylinders. This was also the case with the gasket that was previously installed on the engine. Any risk in drilling out these holes and filing the holes so they actually match the head/block profile?
  12. #117
    6 Post(s)
    Can you show a pic of the other side??
  13. #118
    Jan 2013
    Nowra NSW
    5 Post(s)
    Otherside of the gasket or the head?
  14. #119
    6 Post(s)
    The top of the head.. where the adjusters are.
  15. #120
    Grab a dermal and thin cutter.
    Main aim is to keep all edges smooth and round.
    So grab a course cutter and a fine one..
    And go nuts opening them up a little.
    I'd recommend no closer to the bore, but can go out a little
  16. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Parksy (17th March 2014)
