Results 1 to 10 of 13
Thread: Td42, silver top or blacktop?
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    Hi all
    Have searched to no avail.
    How do you tell the difference between the blacktop and silvertop motors?
    And which of the 2 was put in the gu's?
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
    334 Post(s)
    Rocker cover is either Silver or Black. The Blacks came out in the later GQs and All the GUs.
    The Silver top is the pic though.
    Feb 2011
    Shed
    45 Post(s)
    What he said
    Nov 2011
    Toowoomba, QLD
    Thanks for that. Just wanted to know what was in my gq.
    Legendary happygu's Avatar
    Both are very strong, but the Silver Top, and later Turbo Black Tops, are stronger. The Silver Top had larger stronger Gudgeon Pins, and heavier pistons, and as such were a little lazier, but handle a bit more boost and modification.
    The earlier Black Tops were made slightly lighter internally, to make them a little more refined and car like ( Toyota like )
    Mic
  6. The Following 2 Users Say Thank You to happygu For This Useful Post:
    Bushy674 (28th June 2014), Woof (24th March 2014)
    Jan 2013
    Silvertop and N/A blacktop 28mm gudgeons, Factory turbo black top 30mm gudgeons.
    Statisically order of strength is:
    - Factory turbo blacktop
    - Silvertop
    - N/A blacktop
  8. The Following 2 Users Say Thank You to Dales300exc For This Useful Post:
    @GUte (16th March 2014), Bushy674 (28th June 2014)
  9. #7
    22 Post(s)
    The only real difference with na black and silver top is the pistons. Many people will tell you that NA black top piston are weak. They are just weaker than the silver top, but they arnt a weak piston..
    I have been running more boost on my factory NA blacktop for years now, the majority of that time over 20psi. Now at over 30psi they still havnt cracked.
    Edit.... I hope my pistons let go before the crank does anyway, at least I can limp home
    96 GQ coil/Cab
    08 G6eT
  10. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    growler2058 (16th March 2014), Woof (24th March 2014)
  11. #8
    Mar 2014
    I was also told the vac pump is in a different position, silver top are off the alternator and black tops are near injector pump, is this correct or am I being told stories?
  12. #9
    There is a member [sherro] who has just fitted an inport 4.2 in his GQ sounds interesting to me
  13. #10
    Patrol Freak Sherro's Avatar
    Feb 2014
    Logan, QLD
    Quote Originally Posted by davo82 View Post
    Yer Davo the later td's had the vac pump under the ip a good idear i thought till it came time to pull out the ip what a pain in the butt but the sky's the limit when it comes to alternators.
    Sherro
  14. The Following User Says Thank You to Sherro For This Useful Post:
    davo82 (25th March 2014)
