Results 11 to 20 of 33
Thread: GU with AutoHubs. Will a LOKKA be a problem?
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Quote Originally Posted by megatexture View Post
    Thought yours looked stock, at glasshouse when Matty said all us auto boys with auto hubs you didn't say yours were manual when he stopped to unlock his lol
    Yeh, looks can be deceiving (lol), a great thing with a auto lokka ,you can still drive in 2wd with the hubs manually locked in, no problem, so I just unlock them when im airing up , saves getting out/stopping twice.
    Anyway, all you boys with full Auto hubs, are crazy if you don't manually "lock" your auto hubs in doing glasshouse tracks, especially the tracks you drive Troy (haha)
  2. #12
    brisbane
    Never had any problems yet touch wood lol
  3. #13
    Unafordable
    4 Post(s)
    I had to convert auto hubs to manual almost 5 mins after fitting Lokka as I couldn't stand the clicking in every corner.
    Either fit manual hubs or convert auto ones to manual only.
    Quote Originally Posted by Nessie View Post
    Hi guys, i have a wee questions regarding changing from Auto hubs to Manual.
    i am not the most mechanically gifted person, is it a big job to change swap them over?
    i have a 98 GU Patrol. i bought some 2nd hand manual hubs to swap them over, but just not sure as to the ins and outs.
    any advice would be great!
    6 bolts on the locking hub.
    Slide off auto hubs, slide on manual hubs, do bolts up...
    Sent from my SM-G800Y using Tapatalk
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
  6. #15
    Mar 2017
    As i am new to the Nissan patrol, good information.
    cheers
  7. #16
    476 Post(s)
    Old post but its not just as simple as that. Going from Nissan Auto hubs to Nissan Manual hubs you will also require the egg rings and also the step ring for the inner part of the hub to run on.
    BigRAWesty (31st May 2017)
  9. #17
    My autos have the outter egg ring in them.
    Had a Lokka in my '07 CRD for about 6 years with Auto hubs and never a problem.
    Worked perfectly and behaved exactly the same as a normal open diff
    It is very important that the 'float' on the axles is correct when setting up the Lokka.
    If not then it can cause a few different issues.
    If the Lokka and diff are set up correctly and the hubs are clicking that is 99% chance it is an issue with the hubs that should be addressed not the Lokka.
    If the Lokka clicks on corners then, again, the hubs or axle float clearances are at fault not the Lokka and the reason should investigated and rectified.
    With or without a Lokka you should manually lock Auto hubs for a days wheeling anyway (as per the Manual).
    Having said that the mod to prevent the Auto function in the hubs is very straight forward and handy if you ever want to use low range 2WD for reversing trailers etc
  11. The Following User Says Thank You to the evil twin For This Useful Post:
    shantillylais (13th August 2017)
  12. #19
    476 Post(s)
    Yes its part of the hub. So it locates the hub centre. The manuals don't have this part. Hence the need to buy the egg ring. You push the egg ring into the wheel hub and thne the locking section has something to locate on. And the step ring is used for the inner gear section to run on as its separate from the out piece of the hub. Unlike the auto's where its all held together when you remove it. Manuals are good but a pain when it comes to wheel bearing servicing as you need to remove the egg ring to get the outer race out.
  13. #20
    Youve lost me a bit but my minds off with the fairies atm..
    My autos have a singke ring in the hub which i had to remove to do bearings.
    I do remember a stepped ring on my old gq, is thats what is needed to locate manual hubs to wheel hub??
