Results 11 to 20 of 23
Thread: 82 hilux ute
    For $1300 you're not going to get a huge amount of good points, no matter what the car is. Reckon you'd be better off getting a cheap arsed runabout car and saving up a little dough for another 4wd. But that's just my humble opinion
  2. #12
    Expert luke28's Avatar
    Well I definitely need something asap now bastard mq
  3. #13
    Whats peoples opinions on jackaroo
  4. #14
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    common mate, this is a patrol forum, we all own patrols for the same reason so you aren't going to get to much help regarding other cars sorry! Try a 4x4 forum in general, wide range of different vehicles on them.
    GQ Snorkle Lockers front n rear
  5. #15
    Well heaps of people have had hiluxs, range rovers etc. So it cant hurt to ask
  6. #16
    84 Post(s)
    V6 Jackaroos are a real pain to do anything on, engine wise. Dads Jackaroo on gas has towed a 18-20 foot caravan on a 20000 k trek around Aus. The gas caused head issues. I helped strip the heads off and it was an absolute nightmare. It took almost 5 grand to repair. (New pistons, rings, honing the bores, reconditioning the heads, gasket kit, timing belt, thermostat etc, etc). Dad has stripped the gas system out and fitted a long range and aux fuel tank, ready to tow the van to WA and back. Body and suspension is still in pretty good nick.
  7. The Following User Says Thank You to mudnut For This Useful Post:
    luke28 (18th February 2014)
  8. #17
    @mudnut just wondering if you know if patrol and jackaroo wheels are the same stud pattern I know there both 6 stud
  9. #18
    like I said before, I honestly believe if you were to buy a cheap arsed 4by you'll probably end up having to spend a bucket load just to keep it on the road.
  10. #19
    84 Post(s)
    They are a six stud pattern, but the measurements and offset may be different. Hopefully, some one in the know, will have the answer for you.
  11. #20
    Patrol Guru
    Apr 2011
    Melton
    The diesel jackroos HAVE big isues with there injectors - leaking - cost big $$$$$ to fix.
