Results 1 to 10 of 10
Thread: auxiliary cooling fan for techniice fridge
    Dec 2013
    Question auxiliary cooling fan for techniice fridge
    HI, I am having trouble with my techniice fridge cutting out on real hot days in the back of my patrol. If I take it out and sit it on back veranda it will work fine. I have mounted it inside one of my draws (with cut outs to help with air flow)allowing me to pull it out and reach in easier. I don't have enough air flow. I tried a small fan from computer still no luck as it only had low volume. I read on the forum here somewhere about someone installing a fan from jaycar to solve their dramas but I'm stuffed if I can find the thread again, can some one help please. I have room for a 7" fan.
    thanks Kevin
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    what I did was put some polyurethane box inside the cover
    with cut outs for the fan works fine for me and on the lid as well
    any temp above 30d will give you trouble
  3. The Following User Says Thank You to Sir Roofy For This Useful Post:
    kevingalloway (8th February 2014)
    take your pick from any of the 12v fans should be an easy fit up I did it years ago on my engel but cant re call fan part number
  5. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    janderson (8th February 2014), kevingalloway (8th February 2014)
    Dec 2013
    Roofy
    outside temp is above 40 degrees when I have trouble.
    humid temps that high and not many fridges will work except maybe the national luna Trail blaza
    Dec 2013
    Was wondering if a Davies Craig 8" 12v thermo fan was practical at all. I know it will draw a fair bit but if I only use it when temps get up. I may have to put in a temp probe to turn it on at desired temp.
  9. #7
    TRAFALGAR VIC
    35 Post(s)
    humid temps that high and not many fridges will work except maybe the national luna trail blaza
    agree with 3d doesnt matter what you have with that temp in the car
    or any where else it will struggle
    if your down in the minus,s youll have trouble for sure,if you want cold
    set it at +3or4 see how that goes
    if your traveling in the heat turn your air con on
  10. #8
    Ballarat, Vic
    178 Post(s)
    Quote Originally Posted by roofy View Post
    Quote Originally Posted by kevingalloway View Post
    Roofy
    We just had a week away in our bus up near Ballarat where it was consistently & officially ‘bloody hot’. Days of 40+ degrees. Saw 48 degrees inside the bus. Our 133 litre upright compressor fridge (vitrifrigo with Danfoss BD35 compressor) kept stuff frozen solid in the freezer compartment & the fridge compartment between 1 & 4 degrees throughout. Solar saw our batteries fully charged by 1pm each day. The remote compressor unit has an additional 150mm computer fan fitted which runs whenever the compressor runs.
  11. The Following User Says Thank You to Cuppa For This Useful Post:
  12. #9
    Expert janderson's Avatar
    Bearii Vic
    3 Post(s)
    G'day Mate. Where did you connect the fan for the 12V supply
    1st G60 Then MQ Now GU
  13. The Following User Says Thank You to janderson For This Useful Post:
  14. #10
    Dec 2013
    I have 2 12v outlets in the back, fridge in one fan in the other both on the one 6mm twin wires from second battery
