Page 55 of 262 FirstFirst ... 5354555657 ... LastLast
Results 541 to 550 of 2619
Thread: The Knife Thread
  1. #541
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Here is a site with full measurement conversion for scales pins and screws
    http://mdmetric.com/tech/cvtcht.htm
    And a site for pins, rivets and mosaic pins
    http://www.knifeblanksaustralia.com/...1029445?page=1
    www.swat4x4.com
  2. #542
    Feb 2012
    30 Post(s)
    whOOps, had to do it, just scored this badboy
    www.swat4x4.com
  3. The Following 2 Users Say Thank You to oncedisturbed For This Useful Post:
    BigRAWesty (29th January 2014), Gecko17 (30th January 2014)
  4. #543
    Quote Originally Posted by oncedisturbed View Post
    How thick is that thing..
    Feb 2012
    30 Post(s)
    4.6mm across the back of the spine at it's widest
    www.swat4x4.com
  6. #545
    That's a biggin
    Feb 2012
    30 Post(s)
    Oh yeah going to look at maybe using jarrah scales and use rivet screws to fasten them with a countersink bit
    www.swat4x4.com
  8. #547
    Nice blank, here's an idea for the handle,
    Now you'll need to make a sheath for it
    http://www.ebay.com/itm/281087598821...84.m1423.l2648
    Have all the brass cut ,now need to shape it a bit better before putting it on , as it will generate too much heat.
    I have small brass rod that will be perfect ,middle pin is a bit of a worry
  9. The Following User Says Thank You to threedogs For This Useful Post:
    oncedisturbed (30th January 2014)
  10. #548
    Patrol Freak Gecko17's Avatar
    Mar 2013
    I have HEAPS of Jarrah if you need any... bench saw and thicknesser too to dress if you need to.
    2006 Ser IV GU, 6.5l TD V8 Chev with 4spd Auto, 3in Lift, 35in Kumho's, 12000lb winch, Nissan snorkel, Diff breathers, lightbar + Lightforce HD spots on roofrack. Built to go bush.
  11. The Following 2 Users Say Thank You to Gecko17 For This Useful Post:
    oncedisturbed (30th January 2014), threedogs (30th January 2014)
  12. #549
    these are the clamps I use plus I have some small 2" vices that help as well.
    As you can see I have an edge on it now.
    @OD that's a lot of width for a 5.5in blade
  13. #550
    Feb 2012
    30 Post(s)
    Nice clamps, need to get something like that as well, already 2 small vices.
    With it's size, should be nice and sturdy.
    www.swat4x4.com
  14. The Following User Says Thank You to oncedisturbed For This Useful Post:
