Results 1 to 10 of 18
Thread: Turbo - to cool down or not to cool down?
    Expert Patrol-Guy's Avatar
    Dec 2013
    NSW
    So do turbos need cooling down for a few minutes before turning off the motor after a long trip or do you just turn the motor off and walk away??
    I don't switch off unless the pyro is under 150 deg
  3. The Following User Says Thank You to Winnie For This Useful Post:
    Patrol-Guy (29th January 2014)
    Don't just turn it off after a long run, If you don't have an EGT gauge fitted and going on a trip and you have been sitting on 100kph.
    when you get to your destination let it idle for a few minutes , this will allow temps to even out, and the exhaust temps to fall
    If your just going to work unless you drive like Mario Andretti, by the time you grab your wallet, papers ,briefcase ,whatever should be enough time to let exhaust temps come down.
    after all there is not rush, is there?
  5. The Following User Says Thank You to threedogs For This Useful Post:
    It's not so much the length of the run as the latent heat in the Turbo/Oil/Engine if it has been working hard.
    If you fang it thru the 'burbs and screech into the driveway with EGT's up around 400 then it needs a decent cool down period.
    If you drive 1,000 kilometres but the last few K's or so sedately and the EGT's are down then its OK to switch off immediately.
    My rule of thumb is similar to Winnies...
    If the Water Temp is around 87-89 deg AND the EGT is below 200 I'll switch mine straight off.
    If the temps are higher then I'll select a suitable interval on the Turbo Timer or sit and monitor the temps are suitable before I switch off.
  7. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    Family4x4 (21st February 2014), Patrol-Guy (29th January 2014)
  8. #5
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    If you could see the turbo during a long run at speed at night, it would be cherry red, they need to cool a bit before shutdown IMO.
    Cheers, the ferret.
  9. The Following User Says Thank You to the ferret For This Useful Post:
  10. #6
    You used to say 200 degrees, are you getting more delicate these days...lol
  11. #7
    Jan 2014
    tassie
    totally agree about the rush thing
  12. #8
    That was the old turbo haha. This is the new one that I paid for with my precious dollars so I want it to last. Hahaha
  13. #9
    Advanced menis's Avatar
    Mar 2011
    what are the side effects if you dont let it idle and cool down?
  14. The Following User Says Thank You to menis For This Useful Post:
    Patrol-Guy (31st January 2014)
  15. #10
    NT
    Thea small layer of oil solidifies on the turbo/pipes (think a sort of cholesterol effect). Eventually the turbo can't be lubricated/cooled effectively.
  16. The Following User Says Thank You to P4trol For This Useful Post:
