Page 6 of 14 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 136
Thread: Fletcha's New GU Wagon
  1. #51
    If I had nothing on I'd come up and give you a hand, bummer
  2. #52
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    Thats ok mate one of the boys from work gonna give me a hand so shouldn't take long on a 2post hoist
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  3. The Following User Says Thank You to big_fletch For This Useful Post:
    threedogs (23rd January 2014)
  4. #53
    Oct 2010
    Tatura VIC
    Well out with the old and in with the new, old suspension removed and new flexi 2" installed.. The ride on the new suspension with the procomp shocks is amazing, so smooth its incredible
    Apprentice Sparky
  5. The Following User Says Thank You to big_fletch For This Useful Post:
    NissanGQ4.2 (25th January 2014)
  6. #54
    476 Post(s)
    Sits good fletch. Makes me think I need to get new suspension for mine
    big_fletch (26th January 2014)
  8. #55
    Western suburbs of Melbourne
    11 Post(s)
    Looking good Fletch. Loooookin gooood.
  9. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
  10. #56
    2" Flexi MMMMmmmmmmm
    would it flex more than a normal 2" lift or
    would it flex quicker?
    As I need a suspension as soft as possible, but difficult
    because of winch, bar and dual batteries
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #57
    Oct 2010
    Tatura VIC
    Sits at height of a 2" but flexes like a 4" as its running 4" shocks.. I asked for the most comfortable shock they had and after doing some research ended up with the procomps.. They are smooth as anything.. Next time your up this way you can take it for a drive and mine has winch bar and duel bat as well
    Apprentice Sparky
  13. The Following User Says Thank You to big_fletch For This Useful Post:
    threedogs (26th January 2014)
  14. #58
    Done as I know the shocks are about the comfort and all shocks are different,
    I only have EFS ATM and never been happy as always thought it should be softer.
    Early Feb we are coming up I think
  15. The Following User Says Thank You to threedogs For This Useful Post:
  16. #59
    what specs are the carter pump as in PSI and GPH, sounds like a sensible mod
    Is it just a Carter universal
    Also did you use extended brake lines Etc
  17. The Following User Says Thank You to threedogs For This Useful Post:
    big_fletch (31st January 2014)
  18. #60
    Advanced Sonterr's Avatar
    Jan 2014
    Brisbane Northside
    Hey Fletch, what brand are your 2" flexi coils?
    Might keep these in mind if I cop too much heat in future from the blue boys running my 4"..
  19. The Following User Says Thank You to Sonterr For This Useful Post:
