Results 1 to 10 of 17
Thread: Speed Wobbles, pulling left.
    Patrol Guru Timbo's Avatar
    East Melbourne
    I've been to a couple of mechanics and also Pedders to solve a problem. Wanting to fix the car up all nice in case someone wants to buy.. but even if I keep it, I want it fixed!
    Car was tracking beautifully and then I went 4WD'ing last year. Now it's pulling left a bit and has the patrol steering wheel wobbles.
    Pedders report says the following;
    Leading Arm bushes - Bushes Torn, requires replacement x1
    Panhard Rod - Excessive movement x1
    Engine Mounts - Need replacing (getting done next week)
    Wheel bearings - Bearing play and ball pivots x2
    Trailing arms - bushes torn require replacement
    Panhard Rod - Bushes soft, recommend replacement
    Now, I've had 2 mechanics check through this. Both said, don't worry about the ball pivots. There is only a very slight movement in them and it's not going to give you symtoms of your current problems.
    Wheel bearings, slight movement.
    Trailing arm, def replace the bushes. Do both, not just one.
    What I want to know is, what parts are specifically involved in the car tracking straight and or causing wheel wobbles?
    I know the wheel bearings can cause wheel wobbles and I also know the wheel weights on the wheels can cause some wobbles. But as for the rest of it, I can't see how it would cause the car to pull left and shake the wheel at around 80km's.
    Any advice appreciated.
    Did you have wheel wobbles? Car pulling to the left or right? What was the actual reason??
    ps. Pedders bill was over $2,000.
    wheel bearings only need a little movement for the whole lot to wobble and shake under brakes.
    You have a fair few things wrong so I would be replacing them all when Funds allow it
    , as for pulling to one side check your tyre pressures
    Pedders would be at the high end of quotes a lot you could do yourself
    It's a tough call and you can change one thing and solve it, or spend months chassing your tail.
    I'd start with bushes. Pull the radius arms out and do radius bushes and chassis bushes.
    Then do rod ends if no good.
    If the above fails then it's bearings..
    Sorry I can't be more precise. But you really can't confidently pick one thing..
    I pulled my front end off and did the lot in one hit..
    Mine now drives awesomely and with no dampener..
    is awesomely a new word and if so can I use it please LOL
  5. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    Avo (24th January 2014), BigRAWesty (24th January 2014)
    East Melbourne
    Cheers guys for the advice. I don't don't think these things were really that tiptop when I bought it. I'll Def start off with your priority list thanks.
    Patrol Freak kevin07's Avatar
    georges hall
    what sort or tyres do you have. have they been rotated properly check them first
    13 y62 the beast that burbles
    Mine did have the dreaded Nissan 80kph wobble, but was only my wheel bearings.
    If you run mud tyres chances are they'll tend to "wobble more than an AT tyre,
    Chunks missing etc
    salmon3268 (24th January 2014)
  10. #8
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Hey Timbo,
    Do a quick search on Pedders quotes, there is a bit of history there. I'd recommend you get it checked by an independent operator.
    Jack
    2024 Isuzu MUX
  11. #9
    Jan 2014
    Cheers I think that's what I have
  12. #10
    Patrol God Stropp's Avatar
    36 Post(s)
    yes mine had the shakes, cost 800 to get all the front end bushes replaced, it drives superbly now.
