Results 1 to 5 of 5
Thread: Fuel Supply Problem
    Mar 2011
    Fuel Supply Problem
    Hi Guys
    I have a 2005 td42t which will not rev much past 2500 revs under load
    and in neutral shudders badly at 3000 revs while blowing smoke it finally clears and revs through.
    Any ideas
    Justin
    Expert HippoNZ's Avatar
    Feb 2011
    New Zealand
    not 100% sure but maybe a start, make sure your air filter is clean and also check to see if your injectors arn't blocked. could also maybe an error with the on board computer not telling what the truck should be doing properly.
  3. The Following User Says Thank You to HippoNZ For This Useful Post:
    dozer38 (3rd March 2011)
    Mar 2011
    Thanks for that i have a mate who has borrowed the nissan plug in for the weekend, if we can reset and get some joy i will let you know!
    Mar 2011
    Dirty fuel possble change fuel filter also a small amount of water in fuel will do this
    Expert 89GQ's Avatar
    Adelaide South Aus.
    Sounds like air! Give it a good bleed
    89 GQ TD 42
