I decided to open topic about my gearbox problem, it doesn't work properly. i'll try to explain what problems i have exactly. i hope you will help me.
1. When i select "D" (drive) postition, "2" or "1", car starts moving very slowly, it doesn't have power, when i push gas pedal it has no reaction, it still continious moving slowly.
when point approachs 2000 r/min then i feel a bit power.
It doesn't do "kick Down" too, when i push gas pedal it doesn't cluch down to accelerate.
2. Gearbox starts working from the gear i have selected, for example: If i select "2" position, it starts from second gear and not from 1st gear, it doesn't bear if the car is stopped and starts moving.
3. POWER light isn't on but came on once recently it doesn't show if i select AUTO/POWER, it's permanently off however the hold light shows
4. when i move 50-60km/h speed and select "D" position gearbox doesn't select in "3" gear, it just stays in 2nd
5. I took the gearbox sump off today and there was no contamination ant the magnet was virtually spotless the ATF fluid is still nice pinky red and shows no sign of contamination.
6. I have tried to put it into self diagnosis but with the power light not showing it won't diagnose
Sorry for the big post but I'm need to give a good description.
