Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 73
Thread: I want more torque, Cheap options?
  1. #21
    They are just high maintenance, get yourself some MAF cleaner
    from super cheap and keep it in the Patrol and the correct torx tool to remove it,
    I've just ticked over 200,000Ks with no major problems other than a broken alternator
  2. #22
    Expert ThomasWatson's Avatar
    Jan 2014
    Sydney NSW
    Mine has 322000 on the clock but just run into a wierd issue the engine light came on and now on initial take off had to press the accelerator twice
  3. #23
    Jan 2014
    Sydney NSW
    My dad said it's more than likely O2 sensor or tps
  4. #24
    Sounds a bit like over boosting or limp mode needing to press the pedal twice.
    Disconnect the battery for 1/2 hr or so, It will do it again until you can control the boost
    as in manual boost comtroller
  5. #25
    Search NADS are start spending..
    Jan 2014
    Sydney NSW
    Manual boost controller = Dawes and Needle Valve?
  7. #27
    engine light might also mean blocked fuel filter
  8. #28
    Jan 2014
    Sydney NSW
    I changed the fuel filter and primer pump last month
  9. #29
    Expert oddkid82's Avatar
    Apr 2013
    Quote Originally Posted by ThomasWatson View Post
    What fuel filter did you use?
    I used a repco brand one and the patrol didn't like it, engine light came on. Changed it over for a genuine one and no problems.
  10. The Following User Says Thank You to oddkid82 For This Useful Post:
    threedogs (13th January 2014)
  11. #30
    yeah manual boost controller is a Dawes Valve
