Page 33 of 262 FirstFirst ... 3132333435 ... LastLast
Results 321 to 330 of 2619
Thread: The Knife Thread
  1. #321
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    If you have a look over at iknifecollector.com where I am also a member, there is heaps of info there on different brands and their markings
    www.swat4x4.com
  2. #322
    Patrol Freak Gecko17's Avatar
    Mar 2013
    Quote Originally Posted by oncedisturbed View Post
    OD, have you been on the Australian Blades Forum? Any good?
    2006 Ser IV GU, 6.5l TD V8 Chev with 4spd Auto, 3in Lift, 35in Kumho's, 12000lb winch, Nissan snorkel, Diff breathers, lightbar + Lightforce HD spots on roofrack. Built to go bush.
  3. #323
    Heres a handy gadget for your folder
    http://www.ebay.com.au/itm/261356496...84.m1423.l2648
  4. #324
    Feb 2012
    30 Post(s)
    That is sweet TD, will have a look at them properly.
    @HL - yup I am on AB forum as well, some good info and lots of experienced makers on there as well. Bit pricey for their gear though
    www.swat4x4.com
  5. #325
    @ OD they also sell a small brass clip that does the same thing, postage is the killer there
  6. #326
    Mar 2013
    I joined a few months back baut haven't had a chance to have a good look around the site.
  7. #327
    Mar 2013
    Postage still the same if we all purchase a few?
  8. #328
    Feb 2012
    30 Post(s)
    Not sure tbh, gonna see if I can tap into a few contacts and see what they use
    www.swat4x4.com
  9. #329
    @ OD as I'm not up to par with folders , how hard would it be to change blades?
    want to buy a 110 Buck and fit a Damascus blade to is, which you can buy. easy yes or,,,,,,
    http://www.ebay.com.au/itm/221085421...84.m1423.l2649
  10. #330
    Feb 2012
    30 Post(s)
    Sweet. It will depend on how the bolsters are fastened. The 2 I am making at the moment have a single pin in the top bolster which also secures the blade and the bottom bolster has 2 pins securing the bottom back spring in place.
    If you can see the pins then very easy to replace, bit harder if the pins are hidden inside as part of the top boslter unless the top bolster is only a civer for show then it should pop off
    www.swat4x4.com
