Results 1 to 4 of 4
Thread: Power loss
    Patrol Guru Morton's Avatar
    Sydney West
    Power loss
    Hi all, I have a stock 3L, no mod at all bar a full tig intercooler 3 yrs ago, on the weekend I was towing my camper, weather was warm, I keep losing power around 2500rpm, foot on/foot off would help for a few second but start to die again till it get to about 2-2200 rpm then kick in again, sometimes it losses power just under 3000rpm but is fine above that, no lights, just a loss of power/revs, it has always had a slight loss between 2500-2800rpm but really noticed it this trip, on one hill it had a loss of power & I had to drop back to second gear to climb the hill, it actually got 3/4 temp up, it has never overheated ever on a climb like that.
    I recently cleaned the maf sensor 4-6 weeks ago, oil & water is correct, new glowplugs, aux battery replaced 4 weeks ago & cranking battery was shimmed as the loose terminal on the cranking battery killed my aux battery, it has never run better/smoother with good power so this attitude has come as a bit of a surprise to me.
    Has anyone sorted this problem completely, I know a small lose of power is common enough but this was very noticeable,
    regards
    Jim
    2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
    Sydney West
    so no one has experienced this
    Patrol God Stropp's Avatar
    38 Post(s)
    sorry mate i have a 4.2 not much of an idea with 3ltr
  4. The Following User Says Thank You to Stropp For This Useful Post:
    Morton (8th January 2014)
    sunshinecoast
    3 Post(s)
    the year model of your gu is in the main grenade era . I think you should do the full nads program on your motor . I have a later model with few Ks so I have only done the catch can at present . there is lots of info here and others with more of an understanding of the issues than me . but at a guess I would think it is overboosting and going into limp mode until you lift your foot off .
  6. The Following User Says Thank You to nipagu7 For This Useful Post:
