Results 1 to 10 of 13
Thread: 31inch to 33inch
    Advanced Dougy's Avatar
    Jan 2013
    31inch to 33inch
    Hi all, I have a 2 inch lift on my 2011 gu st patrol and am running 265/70/r16 wranglers on it. Which I believe is around a 31 inch tyre. I want to go to a 33 inch tyre as I reckon they are a better offroad size. Would a 285/75r16 be ok to put on without the tyre scrubbing? Also will that size bolt on to the back door for the spare?
    Yes mate you will have no dramas at all.
  3. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    Dougy (4th January 2014), Tobes (9th January 2014)
    Sep 2013
    You'll have to remove the front mud flaps
    2005 ST-S 4.8
  5. The Following User Says Thank You to Snapcatcher For This Useful Post:
    Oct 2011
    Essendon
    X2 with Winnie mate. I don't believe there should be any dramas.
    I'm not 100% sure but think you can get 35's under a GU with a 2 inch lift without any dramas.
  7. The Following User Says Thank You to Drewboyaus For This Useful Post:
  8. #5
    334 Post(s)
    Drew and Winnie, what offset rims are you guys running on your GQs??
  9. #6
    Oct 2011
    Essendon
    I'm standard offset.... -13 I think. (Edit)
  10. #7
    Mine is -22
  11. #8
    X 3
    Unless you are running a weird offset rim, 33's should bolt straight on (incl the spare) without any issues at all.
  12. #9
    Patrol Guru Morton's Avatar
    Sydney West
    Quote Originally Posted by Dougy View Post
    Doug the tyre you are running standard is a 32" 265/70/16, standard GU rims are +10 in the 16's, u can run 33" 285/75/16 & 2" lift with no issue but it will scrub the front mudflaps when flexing with the swaybar on & rear inner guards, same will happen with -13 rim, running -22 is technically illegal but no one will ever pick it up unless your rims are examined, this will never happen, these will scrub very slightly when you have no sway bars connected & is great for rock climbing as you get max flex out of the springs & shocks, be sure to adjust the proportional valve spring for the rear brakes, everyone will tell you it is not required but it is, put some weight in the vehicle or tow something & you will learn very fast you have poor rear brakes, your fronts will lock on dirt or tar in an emergency & you have no steering
    2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
  13. The Following User Says Thank You to Morton For This Useful Post:
    Dougy (9th January 2014)
  14. #10
    Expert Steve4wdin's Avatar
    Feb 2012
    Western Sydney
    I literally did this 2 weeks before xmas. Changed from 17" rims back to 16". 285/75/16. on king rims with a 2" lift. Looks great too. -13 offset. Still had to remove front mud flaps. No biggy. Spare fitted no problem. More concerned about extra weight on door though.
    Steve
  15. The Following User Says Thank You to Steve4wdin For This Useful Post:
