Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Andy's New Ute
    Nov 2013
    Cervantes WA
    Gents,
    The tray is apparently 2200 long (I haven't measured it) so 200mm shorter than standard.
    The chassis is standard length, so I'd guess that as the cab extension is about 300mm, then there is about 100mm more overhang than a standard ute.
    I'll take some pictures of the rear end next time home (I'm working FIFO) and post.
    The overhang doesn't seem excessive and the departure angle should be adequate for the sort of four wheeling that I do. Nothing hardcore, but lots of beach work to get to fishing spots, boat launching duties and occasional touring.
    I've just notice that the water tank behind the rear wheel on the driver's side could hang up and affect the departure angle. Will have to have a look at this and consider installing a poly tank either tucked up under or on the tray. I have one stashed in the shed, so should be a cheap fix.
    Last edited by Cervantes; 18th November 2013 at 08:24 AM. Reason: Water tank comment
    Andy
    2001 GU DX TD42T Extra Cab Ute.
    http://www.nissanpatrol.com.au/forum...Andy-s-New-Ute
  2. The Following User Says Thank You to Cervantes For This Useful Post:
    threedogs (16th November 2013)
  3. #12
    334 Post(s)
    Looks near mate, look forward to some close up pics of that cab extension inside and out.
    Looks good
