Page 306 of 1057 FirstFirst ... 304305306307308 ... LastLast
Results 3,051 to 3,060 of 10561
  1. #3051
    Apr 2013
    intend to use it for the winch..removed starter button ...expanded hole and put in and out rocker in it1388017988531.jpg
    going to put it here...now just have to get the guts and cut the woodgrain ! ha ha ha ha. ..may have to use a slight spacer to get clearance underneath1388018145655.jpg
    the one thing wrong with middle age ...is knowing you will grow out of it !
  2. The Following User Says Thank You to menace 2 For This Useful Post:
    growler2058 (26th December 2013)
  3. #3052
    Apr 2013
    will use the missile switch as an isolator...red light as active indicator ( which really doesnt matter...you know when you activate a missile switch...just good for other people who may put something on the rocker)
  4. #3053
    Apr 2013
    also as a matter of interest and to maybe save people having to go through the process...the accessorary wire from the back of the ignition is the blue one with a red tracer...there is only one....it can be followed down the loom to near the fuse panel...GQ
  5. #3054
    Feb 2011
    Shed
    45 Post(s)
    Got some cable ties out and secured my grille onto the body so it doesn't look so dodgy
  6. #3055
    .......... TPC's Avatar
    63 Post(s)
    You sound like a Land Rover owner doing repairs with cable ties, although they would use rivets.
  7. #3056
    Feb 2011
    Shed
    45 Post(s)
    All the little plastic locking tabs are fubar, the radiator support panel needed some serious panel beating, I did have it tied on with twitching wire, but the cable ties are more durable
  8. #3057
    Apr 2013
    you have to love cable ties....I wish I had designed them
  9. The Following User Says Thank You to menace 2 For This Useful Post:
  10. #3058
    82 Post(s)
    I have nipped up the steering box adjuster and inspected the front end, getting ready for the Otways. I also fitted my new extinguisher on to the drivers seat mounting tunnel. Thanks 3D for the idea of the placement.
  11. #3059
    @ Growler check back here I'll put a pic here of gizmo which may interest you.
    Using "U" bolts you bolt two of these either side of cato straps [uprights] of your bulbar.
    So when out 4x4ing you attach your strap underneath and the access strap you weave on to the strap posts. then if you get stuck person only needs to jump on you bulbar to grab your strap.
    This is made from 1/2" round the bracket is from when I used to make 3 piece sand flags ,
  12. The Following User Says Thank You to threedogs For This Useful Post:
  13. #3060
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    Finally finished my laptop bracket in car and what a job it was very very time consuming to get right.
    Turns around so passenger can watch movies,
    comes in close to me.
    Access to main keyboard if needed, it is touch screen tho.
    8 port power usb hub under dash to mount my cameras and other things I have planned.
    Completely locks into the dash when 4wd.
    Pushed out of the way and protected.
    un plug two plugs and one turn buckle (lost what to call it). 20seconds laptops out.
  14. The Following 4 Users Say Thank You to sil3nt_dr3ams For This Useful Post:
    growler2058 (27th December 2013), NissanGQ4.2 (27th December 2013), Stropp (27th December 2013), threedogs (27th December 2013)
