Page 31 of 52 FirstFirst ... 2930313233 ... LastLast
Results 301 to 310 of 517
Thread: Blocking the EGR Valve
  1. #301
    Dec 2013
    Northern NSW
    Great read guys, very informative. PM sent for acquiring one for my patrol thanks the ferret
    Gold GU4.2 wagon, 3" Beaudesert Exh, Outback rear bar, LCB side steps, factory bar n winch
  2. #302
    Dec 2013
    Northern NSW
    Me again, thanks 2 Mudski for the plate and fast postage, installed on Christmas Eve. All easy thanks to information this thread. Cheers guys
  3. #303
    Feb 2014
    Darwin
    Great post. My nads is nearly complete!!!
  4. #304
    Sep 2013
    albury
    So u guys only bloke off the 1 end not both? Is it worth doing both?
  5. #305
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Just one end, blocked is blocked!!
    Cheers, the ferret.
  6. #306
    Beginner HiluxMichael's Avatar
    Dec 2013
    Austria
    Hey guys, i'm about to fit the provent 200 to my 2.8.
    Regarding EGR and inlet valve block i was told that this could end with higher fuel consumption.
    Can this be true...?
    Mick
  7. #307
    Some people notice a higher boost level and a slight power increase.
    Weather the right foot gets excited by this is up to you.
    You only have to block one end of the egr pipe.. Most do the intake end..
    And also to get the best from the mod a tune is recommended. But if your human keep doing little bits of the NADS then tune once complete a save a few $$$.
    Dec 2013
    Austria
    Blocked the EGR of my 2.8 yesterday - nearly no more smoke, engine runs smother, Turbo spools a little earlier...
    happy as a pig in (well, you know... )
    Mick
  9. #309
    Sep 2013
    Brisbane
    Hi,
    Thinking of blocking the EGR on my 3.0 Di, Series 3.
    Silly questions, but is the best spot on my 3,0lt and where can this be found.
    i know there are lots of pics in this thread, but i just can not seem to figure it out. Also my EGR blanking plate came with 2 holes and not slots, does that mean i need to remove the whole pipe??
    Tx,
  10. #310
    Quote Originally Posted by Beucam View Post
    Hi,
    Tx,
    Late reply but...
    Theres a silver cast pipe on the rhs of the motor that runs upwards to the inlet manifold. IT has two bolts at the top and two at the bottom. The plate goes into the top. Hint, undo the two top bolts and use a long screw driver to ever so lightly pry open the pipe by levering it. it oply needs to open enough for the gasket to drop out and the plate to go in. So only a tiny amount of force i needed. You need to remove the engine cover and its easier on the job if the IC is removed too.
