Page 24 of 36 FirstFirst ... 2223242526 ... LastLast
Results 231 to 240 of 356
Thread: Deaths from towballs
  1. #231
    You ever removed the rear oem loop and seen how its held together? I was quite shocked to say the least.
    Quote Originally Posted by liftlid View Post
    Yes looks can be deceiving, the reality is that if you did manage to damage a factory point you are doing your recoveries wrong! You might have also damaged the chassis as well.
    Yeah my GQ was well held on and I incorporated those points into my rear bar when I made it.
    I was shocked though when we pulled Healy's hook off to find it was held on by very little and the bolts certainly needed replacing. I note now though that we also saw that his rear brake line was fully rusted and as it turns out his Chassis rear end had Catestrophic rust that deemed the car a total loss. Disappointing. I wonder then if his fixings were not representative of most? My GQ certainly was well fixed. There is a cross brace from that fixing going above the fuel tanks diagonally to the chassis rails on both sides.
  2. #232
    @ Kind is that a rear tie down point?. Best place to recover from the rear is any central point .
    Most 4x4 have a class 2 tow hitch receiver and retrieving from a central position is ideal. As someone stated earlier
    if you're straightening OE hooks you are doing it all wrong
  3. #233
    Expert patrol2.8's Avatar
    Nov 2011
    vic
    In my job I would probably use my front recovery point on average over a week about 8-10 times to drag trees out of irrigation channels and around 4 snatches a week recovering work cars while I prefer to use the tow hitch where possible unfortunately there are places where I just cant do that if you take the time to assess the risks involved in every recovery then the front hook should be fine ive now had my patrol work ute for 5yrs and it has just about had everything thrown at it and dragged or snatched everything from trees to 4wds even tractors n trucks and the hook is still as strong as the day I got it
    Theres only one thing tougher than my truck............. YES DEAR GOING TO DO THE LAWNS NOW
    WARNING: Towballs used for recoveries,can and do kill people and damage property
  4. #234
    Nov 2011
    vic
    Hey Tas great job new sticker looks great
    Thanks Mate
  5. The Following User Says Thank You to patrol2.8 For This Useful Post:
    taslucas (9th December 2013)
  6. #235
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Good stuff mate. It fits nicely
    Hello from Under Down Under!
  7. The Following User Says Thank You to taslucas For This Useful Post:
    patrol2.8 (9th December 2013)
  8. #236
    Expert kind's Avatar
    Nov 2013
    brisbane
    Bloody toyota drivers
    1996 GQ 2.8TD 3" straight though, draws and oh so much more
  9. #237
    Beginner Beno's Avatar
    Jan 2014
    Springfield Lakes, Brisbane QLD
    I know of two incidents in QLD where ppl have been killed. PROMOTE THE MESSAGE!!
    __________________________________________________ __________________________________
    “Man cannot discover new oceans unless he has the courage to lose sight of the shore.” ― André Gide
  10. #238
    Dec 2013
    Costa Rica
    Quote Originally Posted by kind View Post
    OMG here in CR people already knows doing this is dangerous; but anyone i know have even see that happening.
    Can I use te pic to show on a local (Costa Rican ) forum ?
  11. #239
    Quote Originally Posted by edsnm View Post
    Absolutely, spread the word. Send the message Global.
  12. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    growler2058 (18th January 2014), Sir Roofy (18th January 2014)
  13. #240
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    U was riding around in some fire trails today. Come across a couple of guys trying to snatch a hung up hilux out of the ruts.
    Both cars has the strap over the towball. I told them it was a no go, and showed them to pull out the hitch and use the pin. (They had no recovery points.) they listened cause on my way baxk out the triton was hung up in a different set of ruts!
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  14. The Following 2 Users Say Thank You to Punderhead For This Useful Post:
    Hodge (18th January 2014), MudRunnerTD (18th January 2014)
