Results 1 to 7 of 7
Thread: How do i know if i have EGR on a TD42t?
    Sep 2013
    Gippsland
    So if someone asks me if i have EGR, am i correct in thinking that if my blow by is feeding back into the pre turbo intake, then i "have" EGR?
    If i didnt "have" EGR then i would have either blocked it or have a catch can?
    GU with a few bits and pieces.....
    Egr is exhaust gas recirculation. It's a duct which runs from the exhaust to the intake.
    People don't remove it as its a road worthy issues to do with emitions control so they blank it off.
    The blow by is a smaller rubber tube from the rocker cover which is ducted to the intake.
    Many exhaust this to atmosphere threw a catch can.
    The cleaner the air going in the better the bang inside..
    So to see if you have a blocked egr you need to look for a thin plate inserted between the flanges for the pipe from exhaust to intake..
    Hope this helps
    Depending on what TD42 you have...
    See this thread for the pic of where you block the EGR on a TD42Ti. From a GU.
    http://www.nissanpatrol.com.au/forum...Egr-block-time
    Sep 2013
    Gippsland
    It's a TD42t, not ti
  5. #5
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    What year model is your td42 some have egr some don't use the search function to find threads with pictures etc
    Such is the rule of honour.
  6. #6
    Sep 2013
    Gippsland
    Its a 05/99 build
  7. #7
    22 Post(s)
    Only the td42ti had an EGR
    96 GQ coil/Cab
    08 G6eT
  8. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    patrolla (19th November 2013)
