Results 1 to 8 of 8
Thread: shock bushes
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    shock bushes
    just trying to fit a set of three inch amada extreme shocks to the gq and I cant get the lower nut on as the bushes seem to big or there isn't enough thread on the pin. Can I put the bushes/rubbers in boiling water to soften them up so I can compress them or is there another way, any help appreciated thanks! this is for the front as the rear went in easy as!
    GQ Snorkle Lockers front n rear
    Has the rubber seated properly?
    Also check thread length? Might be a reject.
    Does it fit with old rubbers?? Might have bagged up the wrong size?
    Expert LachDiggityDog's Avatar
    Jul 2013
    Brisbane, QLD
    Maybe you could try using the search button before starting a thread?
    06 TD 4.2 coil cab, 3 inch lift, front ARB air locker.
    84 Post(s)
    Quote Originally Posted by LachDiggityDog View Post
    G'day LDD, if you know of a thread, then please put the link on your post.
    89GQ, try taking the washers off and start the nut on the thread. You may be able to compress the rubbers enough to get the nut started with the washers fitted.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    89gqpatrol4x4 (17th November 2013)
    Brassall
    LOL you have finally got to say it!
    Brassall
    will go and have a look.
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    1999 GU 4500 dual fuel
    Il dado è tratto
    Brassall
    Quote Originally Posted by NP99 View Post
    Thanks mate, I got them in the end. I compressed top of bottom rubber then held it with vise grips then got a bit of pipe and cut into it so I could put the nut through the side of it then using a jack put it on the bottom washer and jaked it up to compress the bottom washer and the I could put the nut on through the cut out in the tube. wow what a pain in the bum. I watched mudrunners 4wd tv episode and they don't go on that easily at all!!!!!
