Page 288 of 1057 FirstFirst ... 286287288289290 ... LastLast
Results 2,871 to 2,880 of 10564
  1. #2871
    Looks good.
    I started to re do the wiring to run full body lights. I've pulled it all out.
    I'll be re running the wire from chassis to body and tail lights and chassis in New steel conduit for protection.
    It always sounds easy in your mind... And then you start...
    I'm changing a few plugs and putting in new 6 pin water proof plugs..
    And running New 7 core threw the conduit..
    So a bit of a job ahead..
  2. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Hodge (17th November 2013)
  3. #2872
    Are the pics showing up??
    .......... TPC's Avatar
    63 Post(s)
    Quote Originally Posted by Westy's Accessories View Post
    Yep, looks like lots of work.
  5. The Following User Says Thank You to TPC For This Useful Post:
    BigRAWesty (17th November 2013)
  6. #2874
    More than I bloody thought but the out come wI'll be worth it..
    Expert AJTich's Avatar
    Oct 2013
    Andrews Farm
    Geez Westy...All the guts is hanging out.....But as you said, will be speccie when done...
    AJTich
    2004 GUIII, white ST, 3.0L manual wagon, NADS,EGT/Boost,Water Temp/Oil Press gauges, drawers, UHF, stubby cooler on the 4WD selector...
    "I don't get bogged, I have unplanned 4WD training activities..."
  8. #2876
    Quote Originally Posted by AJTich View Post
    Yea it looks bad. For some reason the auto lecky who wired up the trailer plug started from under middle PS door?? So there is 3m of 5core wire from middle of the car to the trailer plug???
    Weird.
    But why mess with what's started??
    Ill tap into this harness for the New lights, splice in the reverse light setup and run it of to either side if the car the split body and bumper from there..
    I've completed both chassis to body looms..
    And a quick pic of the New body lights..
    And I received step one of the sound deadening..
  9. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Stropp (19th November 2013)
  10. #2877
    Expert Malgreen's Avatar
    Yulara
    well i was going to replace the cheap plastic guard in front of the steering arms with a new one from bush skinz... had a look and noticed the the right hand side that bolts that hold it in place ( and location of new bolts ) are missing their heads.... the left hand side one came off easy ( after lots of wd40 ) but the other bolt twisted off with no effort at all.... so now i am stuck with 3 snapped bolts...Bugger...
    i will have to go to the local mechanic to get out as i dont have a drill or easy outs.. once fitted i will post picks
  11. #2878
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Looking good westy. Where did you get those tail lights?? What is your step 2 for the sound deadening?
    Edit: Malgreen, you could try and drill them out. Use a pin punch and knock a mark in the center of the bolt, then use a small drill bit to make a hole the entire way through the bolt. Then go up the next size and repeat, if you're lucky, you won't have to go to big and the bolt will wind it's way into the chassis. Usually it gets to the one size before you start drilling out the thread and it will remove itself.
  12. The Following User Says Thank You to Parksy For This Useful Post:
    Malgreen (19th November 2013)
  13. #2879
    I'll be doing the closed cell water proof foam for the second layer.
    And the lights from patrol a part.
  14. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Parksy (19th November 2013)
  15. #2880
    The top layer has arrived..
    10m2. Bloody heaps
