Results 1 to 10 of 12
Thread: spare wheel gu ute
    south gippsland
    spare wheel gu ute
    hi
    ok have been here a while searched and can not find any thing on this where do you store you spare wheel on a tray back ute if you want to use the hole pick up bed it seams to tight to go in with tank at the back without lowering the tank witch i would rather not do or is it just make the tray higher again ? ideas suggestions photos ?
    thank for reading Roady gu
    Yeah most just lift the tray up a tad to suit not a big job,
    Jul 2012
    Brisbane
    Hi roady GU I also have a Gu and have 285/75/16 and just wouldnt go into the spare holder so have just had the brackets widened and the tray lifted 35 mm.
    Cheers Bradwill
    south gippsland
    hi
    thanks for the reply looks like i will just lift the tray 40mm sorry have not replied earlier but had the Internet down i have a radio connection and i had to wait for service repair man thanks for looking
    roady gu
    Expert Big Red's Avatar
    Feb 2012
    you could mount the spare/spares to a roofrack over the cab i suppose
    You can follow me but its gunna hurt !
  6. #6
    Quote Originally Posted by Big Red View Post
    x2. i have seen a few GU/GQ trucks with a small roof rack ontop of the cabin. it looks neat.
  7. #7
    Nov 2013
    Cervantes WA
    Quote Originally Posted by roady gu View Post
    hi
    Probably too late, but my ute came with a second Reese hitch welded on at the back and a simple spare holder fabricated that slots in to it.
    A bit of a pain if you want to get in via the back of the tray, but does free up space in the tray and avoids putting the weight of the spare up high.
    If you're interested I'll take a picture and post when I'm home on R&R.
    Andy
    2001 GU DX TD42T Extra Cab Ute.
    http://www.nissanpatrol.com.au/forum...Andy-s-New-Ute
  8. The Following User Says Thank You to Cervantes For This Useful Post:
    BigRAWesty (17th November 2013)
  9. #8
    south gippsland
    Quote Originally Posted by Cervantes View Post
    HI
    Andy sound good have temp lifted tray and slotted in spare at back but can only fit 265x16 in there fitting on the back would be better for long touring a pic would be nice
    thank you Roady gu
  10. #9
    Nov 2013
    Cervantes WA
    HI
    thank you Roady gu
    Roady,
    My wife took a couple of snaps of the spare wheel carrier.
    I should explain that the ute is a new purchase and the carrier came with it as is. I do aim to clean it up and give it a lick of paint in the near future. Also may have a look at adding some bracing to stiffen it up slightly, although to be fair it doesn't seem to wobble about too much as is.
    Anyway. Pictures attached.
    The spare towball socket is welded to a crossmember above the towball. The carrier slots in there and is held in place by a pin as your tow ball would be.
    The lower horizontal bar extends past the upright so that you can rest the tire on there whilst lining the wheel up with the studs which are welded to a circular plate at the top of the upright bar. I've just realised that this will need adjusting when I go up to 33" tires later.
    I hope this explains it okay.
    Andy
  11. The Following User Says Thank You to Cervantes For This Useful Post:
    roady gu (20th November 2013)
  12. #10
    Mar 2014
    Hmm, that looks neat. I have normal spare bolted horizontally between tool boxes each side, swag slots in underneath. I do have a small steel roof rack on cab for the second spare when touring.
    Cheers,
    Trev
