Results 1 to 7 of 7
Thread: Petrol / Gas VS Diesel 4.5 or 4.8L which is better ?
    Nov 2013
    Hey i just wanted to know your thoughts , i am looking at buying a GU , hopefully the 4.8 l petrol with gas, if not the 4.5L . my questions is those who have petrol GU's do you find much power difference between the 4.5 to the 4.8L. / gas not on gas, just wanting your side and a list of the pro's and cons. One of mine are is the obvious initial price difference , as a petrol one is alot cheaper. I only live 5 minutes from home so running costs aren't a huge factor.
    Happy to get some responses
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    I run a 4.5 with injected gas, power wise, on gas it is slightly down, but not much. I can still get 500km out of a 120 gas and 35 petrol.
    I barely notice it on gas, I am pretty happy with the power it produces, but for towing I feel like could use more power.
  3. The Following User Says Thank You to lhurley For This Useful Post:
    woosh73 (15th November 2013)
    Expert 4by's Avatar
    Northern Vic
    The 4.8 is a higher tech engine and will go better. Test drive as many as you can before you decide.
    If going 4.5 get manual as its a bit sluggish with auto. 4.5 easy to service and repair simple tappet adjustment and very reliable.
    Read a few posts on both and do your homework before deciding. Dont forget to ask questions. Good luck.
    Cheers 4by
    Can I put a Holden badge on my Chevy ?
  5. The Following User Says Thank You to 4by For This Useful Post:
    woosh73 (16th November 2013)
    Tbh I don't think you'd go wrong with either.
    Both produce around the same sorta mileage figures, ofcourse the 4.8 is more powerful, but is more advanced..
    Ultimately if you could find a 4.2 turbo diesel that's your best option.
    But they require a fat wallet..
  7. The Following User Says Thank You to BigRAWesty For This Useful Post:
  8. #5
    Patrol Guru Evo's Avatar
    Jun 2013
    Lost somewhere in my own head...
    3 Post(s)
    +1 for 4.5 recommendations.
    I have one, manual dual fuel.
    For the weight of it, goes well enough.
    Haven't done a nice long drive to get some range out of it, but around 400kms from 90lt gas around town.
    75 litres of petrol goes a long way when running mostly on gas.
    I can't tell the running difference between the two fuels either.
    But definitely don't rush in and test drive a few.
    When I was looking for mine, I took my time and did a lot of research.
    I wanted a 4.2 TD, looking at upwards of $25k at the time, but then I saw this one, dual fuel, 1 owner from new, immaculate interior, full service records, cost me $7000.
    Bargain I think.
    Evo
    Cheers,
    Evo
  9. The Following User Says Thank You to Evo For This Useful Post:
  10. #6
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    I have a 4.5 with a 105 Useable Gas Tank & 35 Litres Petrol
    I use 18 Litres per 100 K's on Highway Cruising and 22 Litres per 100 K's around town
    On ULP I use 16 Litres per 100 K's
    Don't notice the difference between Gas and Petrol
    The 4.8 would have more Power but I am more than happy with the 4.5
  11. The Following User Says Thank You to Bob For This Useful Post:
  12. #7
    When I had my dual-fuel 4x4 it made no difference in fuel figures, from towing to 4x4 to hwy.
    @ Bob gotta be happy with 580 gas range,
  13. The Following User Says Thank You to threedogs For This Useful Post:
