Results 1 to 8 of 8
Thread: Trailing arm bushes
    Expert Lawrence's Avatar
    St Thomas, Jamaica
    Trailing arm bushes
    Hi fellows, i changed my trailing arm bushes on saturday. The difference in ride quality and handling is amazing, not to mention the noise. The vehicle is now taking the bumps and potholes of the road home in comfort and much less noise. Also gone is the swaying, when driving at a good speed as well as the slight sideways movement from the back when accelerating, Also the ride height from the back has increased by about a 1/2 inch. Next job is the shocks which have been on the vehicle maybe from it was built. They are not doing a bad job, but i know there should be massive improvements in ride with some gas shocks (probably Munro until i can get a suspension change),
    1989 Nissan Patrol DX with the td42 (inline pump). No mods yet except black US 16x8 rims with 265 75 16 Ats
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    What type of bush did you use mate?
    1999 GU 4500 dual fuel
    Il dado è tratto
    Awesome mate, i need to replace the ones on teh GUIV too.
    FYI in relation to the ride height change. Did you tighten the bolts up when it was still jacked up? If you did then you might have got increased ride height but now the bush is twisted and flexed. I would be undoing the bolts while it is sitting in the drive way and retighten them all while the car is sitting in its level ride position.
    If you dont do it as above you will find you will flog out the bushes much sooner than necessary.
    Cheers MR
    Feb 2013
    Broadford VIC
    Cheers MR
    Do you tighten them just enough while up and then to spec when down?
    Il dado è tratto
  5. #5
    Quote Originally Posted by NP99 View Post
    No you really only need to get the bolts in while it is up. In fact if you can get to the bolts you dont even need to jack the car up. do it sitting on the ground. If its on a Hoist though then put it on the ground before tightening anything up.
    NP99 (5th November 2013)
    St Thomas, Jamaica
    Yes, they were tightened on the jack. I will check on this.
    St Thomas, Jamaica
    Genuine Nissan bushes.
    Quote Originally Posted by Lawrence View Post
    No probs just crawl under the car and loosen everything then re tighten it up in the neutral position for long life mate.
  10. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Lawrence (7th November 2013)
