Results 1 to 9 of 9
Thread: Swb patrol auto problems
    Nov 2012
    Chidlow, Perth hills
    Hey guys my shorty patrol has an issue with the gearbox in the last gear. At around 90-110 k's the whole cab will start vibrating and the revs will fluctuate and kick up and down. The cab feels like its going over a million tiny little ruts and the car also feels like it loses heaps of power. Please help! It doesn't happen when in in overdrive or once I've gone past that rev point.
    Advanced jc58nc's Avatar
    May 2011
    Batemans Bay NSW
    Is the SWB raised at all? Owning a SWB Auto myself I went through the whole exercise with a 2" lift, gearbox spacers & adjustable upper arms to get rid of the vibration.
    It's because the rear tail shaft is on an acute angle with a SWB and worse with a 2"lift or higher.
    In the end I put stock height springs back in and problem vibration is all gone.
  3. The Following User Says Thank You to jc58nc For This Useful Post:
    Hoochthepooch (27th October 2013)
    Nov 2012
    Yeah it has a 2 inch lift, I don't wanna go back to stock height! Haha. So pretty much I'm going to have to spend lots of dollars? What if I convert it to a manual will there be any difference?
    There are a couple of threads regarding auto issues, from what I've read it may well be your torque converter or valve body if your revs are fluctuating. I've got a lwb and had a vibration through what felt like the drive train..... (It wasn't a front end shimmy)...... Replaced the left hand engine mount and vibration from what I can tell is no longer there.
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    alot has to do with the geometry of the car - being a SWB
    your choices are not good
    keep the lift and spend $$$$s on new joints and spacers and arms etc to get the "best"angles on the shafts
    or
    take the lift out and run standard hight
    my Bro-in-law years ago(early 90's) spent $$$$ on his G60 as he wanted the look of a Tonka Truck, to get rid of the shakes over 1600RPM(had a 350 Chev in it) in the end he dropped the lift & tyres, so it was drivable
    cheers
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Have moved this thread into the Gearboxes ( Auto / Manual ) section of the forum
    Toddie
    Aug 2010
    adelaide
    why cant you remove lift and put larger tires on the beast
    same effect and a lot cheeper
    OH LEATHER IS NICE
    Quote Originally Posted by my third 256 View Post
    Slight issue with tyres rubbing
  10. #9
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Revs fluctuating and the gears kicking up and down at 90 - 110 sounds like the lockup in the torque converter is playing up.
    But heavy vibration at that speed could be a stuffed uni joint. They would be the easiest to check.
    Hello from Under Down Under!
