Results 1 to 9 of 9
Thread: When you installed your snorkel did you drill holes in your pillar?
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    Hello fellow forumites,
    Almost finished snorkel install on my GU, but the top bracket that is just under the air ram requires 3 holes to be drilled into the pillar then pop rivetted in.
    Wondering if you guys did this and how you went? I'm cautious about drilling holes into a panel which has the possibility to leak water into the cabin, I was thinking of possibly sikaflexing the bracket to the pillar instead?
    What do you guys think/have done...
    Cheers,
    Eric.
    1998 GU RD28T: RIP
    Hello 2012 GU CRDZD30
    Nov 2012
    Coffs Harbour, NSW
    This is the bracket in question.
    1998 GU RD28T: RIP
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    I marked the hole position with the braket on the snorkel then drilled, painted and put big pop riverts in. Just gota be careful drilling the holes, not to go all the way through the other side.
    I don't think silicon would have the stretch to hold it on, plus it could damage the paint and look worse
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
    Simpson Desert GUtsy ute's Avatar
    Apr 2011
    Forestdale Brisbane
    Sikaflex industrial adhesive will do the job, no sweat.
    Used to glue side panels to buses etc.
    Comes in black too, so will match the bracket and fill the holes.
    [SIGPIC]
  5. The Following User Says Thank You to GUtsy ute For This Useful Post:
    trekster (12th October 2013)
    Aug 2010
    adelaide
    silicon on then pop rivet on when still wet and then clean up exess
    OH LEATHER IS NICE
    Mar 2013
    Sydney
    hey buddy, I had a 4" stainless steel steel mounted to the pillar on my GQ and I am not sure what they are called, but the bloke used these threaded inserts with a bunch of sikaflex or black silicone sealant inside before the threaded insert, all high quality stainless steel inserts and bolts.... that was 2 years ago, still no rust and I live near the beach with salt air everywhere.
    Hope this helps.
    @ Gq jack the tool is called a Rivnut tool and works similar to a pop rivet as you drill a hole and pop the rivnut in the hole.
    Great tool not very expensive, I just had a TJM snorkel fitted but their fitting kit comes with nylon inserts for the pillar.
    A handy tip when using a RIVNUT tool is to slightly squash the rivnut then insert. make sure you set the stop plunger
    or you'll strip the rivnut out
    Put masking tape on first then mark the tape. This way your drill wont dance all over the pillar
    Ibbo (30th June 2015)
  10. #8
    Mar 2013
    Sydney
    Ahh rivnuts, cheers threedogs.
    I been wondering what they were called. They would come in handy a lot while building up our 4by.
  11. #9
    Some hear call them nutserts but as my mates use this tool in the aviation industry I'll stick with rivnut.
    M6 aluminium rivnuts are easy to squish, and a good all round size to use , you can get 100 for $10,
    enough for many jobs. I just used some in a flat piece of steel to mount my fire extinghisher, very neat IMO
  12. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    Robo (14th October 2013), rustbucket89 (15th January 2014)
