Results 1 to 10 of 10
Thread: Body swap
    Expert Astro's Avatar
    Apr 2011
    Macksville
    Body swap
    Down the track I'm looking at swapping my engine and accessories into a tidier body. I realise that I probably won't be able to put my 2006 engine into a later body.
    Question: will the TD42i mate up to an auto gearbox without dramas, or should I be looking for a "manual" donor only?
    Steve Kylie and the Kids,
    2006 GU DX 4.2
    Probably not mate. I would expect a conversion kit will be needed. I would be taking your engine and box into the new car when it's time.
    Not sure where you are but give Brett a call at 4wd Obsession to discuss this conversion as he is doing Heaps of them. He always seems to have at least 1 zd30 to TD42 conversion happening mate.
    Apr 2011
    Macksville
    Thanks Mudrunner, I'll check it out
    Sent from my MB860 using Tapatalk 2
    2006 GU DX 4.2
    A td42 will bolt to the autos out of the 3 litres. Getting them to work though is a little trickier but it is possible.
  5. The Following User Says Thank You to nissannewby For This Useful Post:
    MudRunnerTD (8th October 2013)
    Apr 2011
    Macksville
    Are the electrics the problem, Mat
    2006 GU DX 4.2
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    I thought you were not able to get it engineered with an older engine into a newer car. I thought that was basically a "no" because of emissions stuff etc
    Hello from Under Down Under!
    Quote Originally Posted by Astro View Post
    Yeah mate. I think patrolapart have done it or maybe even wholesale automatics.
    As long as you find anything up to 06 you will be fine. You would be laughing if you could get a ti or stl.
  9. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    Astro (8th October 2013), MudRunnerTD (8th October 2013)
  10. #8
    Apr 2011
    Macksville
    My current car is a 2006, so a 2006 or earlier car will be fine.
    2006 GU DX 4.2
  11. #9
    What he said Lucas, all Astro really wants is a tidy body, won't make real difference if its a 2004 GUIV or 2013 GU8 they are near identical. It would be in his interests to avoid something with Traction Control and other mod ons for simplicity so he is probably looking 2005 to 2006 anyway.
    Yeah a Ti or STL would be sweet!
  13. #10
    And they are getting Cheaper and Cheaper Astro.
    Once you have done the swap you will get coin for lots of bits off your current too mate. Coin for your engine, box, diffs etc will offset your purchase for sure.
    Good luck mate. Mat is your man for tech on that for sure bud.
  14. The Following User Says Thank You to MudRunnerTD For This Useful Post:
