Page 91 of 187 FirstFirst ... 8990919293 ... LastLast
Results 901 to 910 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #901
    brisbane
    So 100mm longer do you need to extend the front driveshaft or is this distance gain at the chassis end.
  2. #902
    Quote Originally Posted by megatexture View Post
    yes it is at the chassis end Mega.
    If you have a look at this pic and note that the top mount is in line with the factory mount (in fact it connects to this position for strength) and the bottom mount is set 100mm back.
    and here is a standard Superior Drop Box. the top mount is consistent between the two pics
  3. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    NissanGQ4.2 (3rd October 2013), Parksy (3rd October 2013), sil3nt_dr3ams (27th December 2013)
  4. #903
    brisbane
    Isnt that last pic standard arms with a drop box
  5. #904
    yes. It was the best pic i could find showing the standard drop box location position for the rear joint of the radius arm. you can see that a standard drop box just drops the pivot only inline with the factory setup. the Hybrid that Bene has sorted pushes that back 100mm below the gearbox support.
  6. #905
    Also good flex isn't just about one side tucking hard and other dropped to its limits but good flex will allow the vehicle to stay level while the suspension goes through its travel. You want the suspension to do the work anytime your chassis angles over you have reached maximum flex and you have no suspension left.
    Couldn't agree more. Just in my eyes the patrol setup is like a pin in a sleeve, the arm will rotate all day long allowing good axle rotation.
    I do agree anything more than 2" lift and the bushes are out of there range, but that's when drop boxes come into play.
    As for the toyo setup, the arms will swing up and down all day, but as soon as the arm tries to rotate its very limited buy the Bush and pin.
    It's like putting a bolt threw that pin and sleeve, that pin is only going to rotate as much as the slop (the Bush) allows.
    I'm sure I'm wrong, but in my eyes the Nissan pin setup with drop box is a better setup.
    brisbane
    Ahh ok yep
  8. #907
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    I don't see this mod giving MR an increase in performance over what he has now.
  9. The Following User Says Thank You to liftlid For This Useful Post:
    BigRAWesty (3rd October 2013)
  10. #908
    Quote Originally Posted by liftlid View Post
    Yeah I am not in a hurry to change much now I don't thnk. Keen to see Bene's long arms in the rear though. newby's definition above is spot on and the flex pic of my car on the previous page shows a car sitting nice and flat and level and fully crossed up! I like it. In the car I really had no idea that it had crossed up so much until I got out of the car to take a look. I smiled
  11. #909
    Just cause I like it
  12. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (3rd October 2013), growler2058 (9th December 2013)
  13. #910
    Your just as bad as that bloke and his pics of the things we sit in...
  14. The Following User Says Thank You to BigRAWesty For This Useful Post:
    MudRunnerTD (3rd October 2013)
