Results 1 to 10 of 16
Thread: after market temp guage y61 4.2td
    anyone know what temp y60 4.2td running water temp should roughly be.
    just fitted an after market saas water temp guage and the sender i received with it would not fit
    so connected to the original sensor and went for a drive guage went up to 102 degrees
    when i reconnected old guage sat on about 1/2 way as per normal
    any ideas
    100 is getting warm. generally 70-90 is about normal. The thermostats are normally around the 76 mark.
    Beginner ChrisN's Avatar
    Canberra
    Depends where you measure it. I have a supplementary VDO gauge with the sensor in a fitting in the top radiator hose.
    Easy running in cool weather = 70 degrees.
    Uphill on the highway with trailer = 90.
    Low range 4wd climbs with with a tailwind can see it climb to 120 or higher.
    The sensor should be matched to the particular gauge, shouldn't it? Perhaps the SAAS gauge isn't giving a true reading for the original sensor.
    Chris
    Hi guys, the sensor I got with the guage doesn't fit and trying to get an adaptor to make it fit is difficult as our local auto pro doesn't have a listing for it, I connected the saas guage to the old sender unit which was in there originally and it's giving me readings over 100degrees yet when I connect the original in dash guage sits on half way as per normal. The reason I was trying an after market guage is when towing our van or driving into a hot northerly the original guage climbs quickly but if you easy off the accelerator it drops just as quick. Reading other forum comments I take it the y60 / gu patrol in dash guage is not very accurate.
  5. #5
    30 mins Nth of Newcastle
    I use an engine watchdog from fleebay $149, 3 wires and can set the alarm for the high temp warning buzzer - very happy with it
  6. The Following User Says Thank You to Xfactor For This Useful Post:
    teza04 (5th January 2013)
    Advanced cvando's Avatar
    Aug 2013
    Sorry to dig up an old thread but iv recently replaced my temp sender as well because the old one was faulty and I have an aftermarket guage that came with a sender but the thread was wrong. So iv put a replacement standard one in and I get a temp reading of mid 90s. I have a triple core radiator and a genuine thermostat. Is this just a calibration issue? Should I get an adaptor to suit the sender I got with the guage?
    Quote Originally Posted by cvando View Post
    Yes you should use the sender that suits your gauge.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    cvando (29th September 2013)
  10. #8
    Aug 2013
    Adaptor shopping this week it is then thanks mud runner
  11. #9
    Oct 2010
    Old Bar, NSW
    This is what I did, bought an adaptor from SpeedFlow, you would need to know the threads.
    As they are in Taree I took the bits in and they matched them for me.
    http://www.nissanpatrol.com.au/forum...2&d=1379662967
    Macca
  12. The Following User Says Thank You to macca For This Useful Post:
    dom14 (13th July 2016)
  13. #10
    Jun 2016
    Brisbane
    Hi Macca . . . waaaaayyyyy old thread, but if you can cast your mind back, was the Speedflow adaptor you bought a 12mm 1.25 pitch to go into that hole on the thermostat housing? or did you have to drill and tap it?
    Thanks mate
    Simon
