Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 62
Thread: will a holley and a set of extractors help my rb30
  1. #51
    Patrol Freak Rustyboner81's Avatar
    Perth
    Got another option.
    Bailed on the donor caz of lack of space but my mates mechanic is steering me towards turbo plumbed straight into the carby, bigger jets and a waste gate.
    Its still probably 6 months away but much simpler and no need for a computer still
    '92 (MIGHTY) GQ ST 3.0L Duel Petrol / LPG, 2" Pedders Suspension Lift on 33x12.5x15 BigHorns
    Lukey 2.5" Performance Exhaust with Extractors, snorkel
    Auto Lokka In The Front, Duel Batteries, Stiff Deep Dish Steering Wheel,
  2. #52
    84 Post(s)
    I have heard that turboing a carby engine is possible , but comes with a new set of problems, such as air leaks from the butterfly shaft etc.
    Also, does the transfercase bolt up to the mx7 or ford boxes.
  3. #53
    Also you will have problems with boost pressure over coming the fuel pressure in the carby and pushing it out. Option 1 is a draw threw carby-turbo setup or option 2 is to incase the carby and pressurize the whole thing. All alot harder than fitting efi
  4. #54
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    I would have thought that it would be fairly straight forward to get a vl or skyline turbo engine with all the bits you need and build from that. Theres a heap of aftermarket parts and knowledge for those engines with proven results.
    A mate has been stock pilling any rb30 turbo engine stuff he comes across so that one day he will do that to his patrol.
    Hello from Under Down Under!
  5. #55
    Perth
    Ive been assured its all fine.
    Been assured it will be simple and easy to tune. Theres been turbo carbys before EFI
  6. The Following User Says Thank You to Rustyboner81 For This Useful Post:
    taslucas (19th September 2013)
  7. #56
    Quote Originally Posted by Rustyboner81 View Post
    Keep us informed on how you go. Are you planning a draw thru (carby before turbo inlet) setup?
  8. #57
    Hardcore
    central coast nsw
    Got another option.
    Please don't take offence just trying to be straight forward and honest,
    would of thought efi + turbo was a no brainer against carby + turbo set up.
    Personally I'd be going with efi +computer+ turbo.
    It doesn't come any easyer especially with the RB30.
    yes carby and turbo was before this, that's only because reliable efi wasn't invented yet or was in the to hard basket,
    back then people didn't understand how to set up etc, might say in it's infancy.
    today parts & tuning options especially for a RB30 far out way carby and turbo set up could ever offer.
    computers that can be dyno tuned for beta power/torque you wish to achieve with what parts you fit to engine.
    have the notion that you'll be doing it cheaper, completely understand where your coming from.
    trust me you'll be surprised what can be done off the shelf to what you have if you explore efi+ turbo.
    reliable power and cheaper builds never seem to work.
    guess your planning on going off rd, you want some reliability.
    remember reliable power is always on the lower side of max power.
    you don't' have to build big to achieve good usable results.
    RB30 ( RB stands for race breed) will take alot of punishment on or off Rd, if built correctly.
    Good luck with what you decide to do.
    cheers
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  9. #58
    Hardcore
    central coast nsw
    I dont get it....so a 330 holley will be flooding the engine up until it reaches 6500rpm?
    It's more a mixture of, engine max air flow + the max attained revs and what a certain size carb can flow and mix properly for the given combination.
  10. #59
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by Robo View Post
    ........RB30 ( RB stands for race breed) will take alot of punishment on or off Rd, if built correctly.
    cheers
    I don't think it does, if so what does RD28 stand for? (basically the diesel version on the rb30)
    Or TB42, or TD42?
  11. #60
    Hardcore
    central coast nsw
    Or TB42, or TD42?
    know I read it somewheres.
    Hay It makes sense doesn't it.
    any way here's a link for wikipeida on RB motors.
    http://en.wikipedia.org/wiki/Nissan_RB_engine
