Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Patrol (exhaust) leaving crap behind at start-up
  1. #21
    Jul 2012
    Pottsville
    our work trucks do the same. the exhaust run vertical and if it has been raining you should see the mess it leaves. I would say the condensation over night would be causing this on your troll.
    3lt GU 111 Wagon 2 inch lift,3in Taipan exhaust, cross country intercooler,catch can,EGR blocked, dawes and needle valve,Pyro/boost gauge ARB lockers,steinbaurer chip, long range tank, s/s water tank, draws, warn winch, and other stuff.
  2. #22
    177 Post(s)
    Quote Originally Posted by paulvdw View Post
    Mine does the same. Seemed to be more noticeable after I had a chip and exhaust kit fitted though ?
    Well mine started doing it exactly after a new exhaust was fiited. I noticed nothing with a standard exhaust.
    Quote Originally Posted by Bluecrab View Post
    Gday, safety 1st, bit of carpet so somebody does slip AOT.
    Mght also save the landlord taking your bond.
    Daz
    I clean it up straight away, but of degreaser and it's gone in minutes. Sometimes it's just dry particles, other times, it's wet.
    Advanced menis's Avatar
    Mar 2011
    Quote Originally Posted by Rustyboner81 View Post
    Is that a standard plug socket :what:
    if your talkin bout the power point, it used to be normal untill i backed into it n pushed it through the plaster, now its a recessed point...
  4. #24
    Patrol Freak Rustyboner81's Avatar
    Perth
    Quote Originally Posted by menis View Post
    Hahahahaha that'll teach it..
    Mine does this if i park too close
    '92 (MIGHTY) GQ ST 3.0L Duel Petrol / LPG, 2" Pedders Suspension Lift on 33x12.5x15 BigHorns
    Lukey 2.5" Performance Exhaust with Extractors, snorkel
    Auto Lokka In The Front, Duel Batteries, Stiff Deep Dish Steering Wheel,
  5. The Following User Says Thank You to Rustyboner81 For This Useful Post:
    Hodge (15th September 2013)
  6. #25
    177 Post(s)
    I forgot to reply back here, I'm not sure if it's just a coincidence, but I use the flashlube stuff every second tank. And since filling up last time, it doesn't leave that crap as much any more. Also, it may be just me over-thinking it, but I "think" it does it more when it's sucking from the bottom of the tank, so when it's real low. Will test this theory out as time goes on.
    476 Post(s)
    The mornings are starting to get warmer now so you won't see it as much. Cold air with a warming up exhaust with give condensation....Have a look at cars in the morning at peak hour. Most will drop a bit of water when they take off.
  9. #27
    Mar 2011
    bit of an update fellas, if you see black shiiit on the wall from the exhaust, clean it off asap!!!
    im movin out of the rental into my house im building, and trying to get rid of it is fuucckin terrible!
    might have to paint the wall i think
    :banghead:
  10. #28
    brisbane
    There's your mistake your trying to clean it off with sump oil!lol
