Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
Thread: Question on winches
  1. #31
    Western suburbs of Melbourne
    12 Post(s)
    I thought I would ask the question in regards to my little recovery kit given to me as a gift.
    Comes in small carry bag.
    I have the following bits in it (so far)
    - the E-Z tyre deflator
    - also a tyre gauge with tread depth
    - two pairs of gloves
    - 8000kg snatch strap
    - tow hitch recovery 4.75T bow shackle
    - 2 x 3.25T bow shackles
    - 6000kg equaliser strap x 2 ( one is used to pull logs back to camp)
    Plus still require a 9000kg snatch block
    And a winch rope dampener
    And a tree trunk protector.
    Then I'll need a bloody bigger bag.
    Can you suggest anything else I may have on board, even if its a "just in case" scenario.
  2. #32
    Oct 2011
    Essendon
    Pretty much got it covered.
    Maybe a winch extension strap.......
    Then we've gotta get you out and using it!
    Tip tip tip......tap tap tap....
  3. The Following User Says Thank You to Drewboyaus For This Useful Post:
    MEGOMONSTER (7th September 2013)
  4. #33
    12 Post(s)
    Quote Originally Posted by Drewboyaus View Post
    I know, I know, god damn it.
  5. #34
    sunshinecoast
    hi guys .
    I bought the runva 11000 xp . I think it will be the only runva that will fit as I only have 27mm of clearance between the winch motor and the chassis . I have a 2011 gu7 with arb steel bar . I checked the specs for the other runva's but the motors were longer and not able to be fitted to my car .
  6. The Following User Says Thank You to nipagu7 For This Useful Post:
  7. #35
    Hey Mego your kit looks good mate and drew has called well on a winch extension strap, the bigger the better.
    I would also recommend keeping your snatch strap in a small bag by itself as it is likely to be used more often and you don't have to sig it out of your bigger kit. When out and about mine lives on the floor in the front left under the Navis legs.
    My winch gear lives in the footwell behind the front passenger seat in easy reach. When you need it it is likely that you are situated precariously and need to hold the brakes on Hard and need to reach it and hand it out the window. If in a Bog Hole(don't do it) you also need to hand it out the window so keep it close.
  8. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    cgm (8th September 2013), MEGOMONSTER (7th September 2013)
  9. #36
    12 Post(s)
    Thanks, great points.
  10. #37
    12 Post(s)
    Quote Originally Posted by nipagu7 View Post
    hi guys .
    Don't tell me that. I got a GU8 and a Runva EWX12000 waiting to get fitted up to am ARB winch bar.
  11. #38
    sunshinecoast
    that was the winch I was originally going 4 megomonster . If you get on the runva website you will find the sizes for all the winches , just click on the individual winches and scroll down . the 12000 is about 12mm to long .
  12. #39
    12 Post(s)
    And specifically ask them if it will fit and said yes.
  13. #40
    12 Post(s)
    Went to ARB yesterday to find out if the Runva winch would fit their winch bar and couldn't agree if it would or wouldn't.
    Because the motor is quite long and the mounting point is off centre pushes the winch over extremely close to the bar mount and mounting point.
    I call Runva to see what they say and all I got was a message bank and no return phone call. Pissed off about that. I hate with a passion any business not picking up the phone or getting a return call quickly.
  14. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    Bloodyaussie (10th September 2013)
