Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Can't replace brake pads on GQ front right
    Legendary dom14's Avatar
    38 Post(s)
    I bumped into an unexpected pain in the butt type of problem today. I was replacing the brake pads on my GQ(1990, single piston) front end. All went nicely on the left hand side and it’s was all over less than ten minutes.
    All I had to do was to undo one bolt and lift the calliper top assembly. Then press the piston with a clamp and slide in the new pads, lower the calliper top assembly again. The two bolts that hold the calliper top assembly moved freely without any dramas for me to push it back in again.
    Right hand side is another story. After two hours still I can’t get the calliper top thing to go in.
    The reason is that the bottom bolt is stuck like it’s welded to the calliper body. I can turn it both ways with a spanner, but no chance pushing it in or taking it out. The top bolt is fine, it comes out easily and goes in the same way.
    What can I do to get it to move guys?! Hitting on it with a mallet or hammer didn’t work. It won’t move at all, but it turns, though without moving in or out.
    I took a photo, but can’t post it as I can’t find the USB cable to transfer the photo to the computer.
    I will post the photo tomorrow.
    I tried my best to describe it, but I know a photo could’ve saved me thousand words.
    I have no idea why it’s stuck like that. I had to put the old worn out pads back in. Since they are pretty flat worn, calliper top not moving in(and out)doesn’t affect the ability to lower the calliper top.
    I’m also beginning to suspect this is probably the reason I feel the brakes aren’t good enough to hard stop the GQ when I need to do that. I feel brake’s bit too weak, but I know it’s a heavy car and I got disc brakes on both front and back.
    Any help would be great.
    Thanks guys
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    When rotating your only turning the bolt, the sleeve will be what's fused solid..
    There is no good news with this. You need to remove the whole assembly, and press it out then depending in condition, re-grease or replace the sleeve..
    Happened to my car at around 400 thou. I took it to the specialist so if it needed replacing they could do it there And then..
    Thomastown, Melbourne
    6 Post(s)
    I had all new seals put in mine not long ago and one side had a seized pin..... there was no rescuing it and it had to be replaced.
    Not uncommon when they are not serviced enough considering the places we take these cars.
  4. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    BigRAWesty (5th September 2013)
    38 Post(s)
    Thanks Kallen. I guess there's no easy way out for me this time.
    How about taking it out and leave with some WD40 then attach it to a vice and try some tapping or banging?!
    Quote Originally Posted by Westy's Accessories View Post
    Cheetah Outreach
    How extensive is your parts list. If you wish to do that then I'd be ordering a new sleeve straight up, a some sorta small honing sanding device to clean and smooth Off the inside of the caliper..
    From memory it wasent expensive considering I had my car back the same day.. $150ish from memory..
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Are you talking about the caliper slide?? Or the bolt that holds the slide pin on to the caliper??
    Scratch that. I reread.
    Happened to me not long ago. To be honest, it's a pain in the arse to get it out once it's seized. The only way I eventually got it out was, to take the whole caliper off the car, and belt the slide with a hammer until it came off. I did leave the pin in wd40 and clean it up, re greased and put new seals in. Seems good now, about 8,000km on.
    I'm not saying that's the best way to do it, but it sure as hell worked for me. If that's not something your overly keen on, get another one from the wreckers and rebuild it. Seal kits are pretty cheap
  8. The Following User Says Thank You to lhurley For This Useful Post:
    threedogs (12th September 2013)
  9. #7
    38 Post(s)
    Just attached couple of pictures.
    I wasn't good with the terminology. But, I reckon it's bit clearer with the pictures.
    Thanks mate.
    P.S. In the second picture, the bolt on the ground is the one that goes into the slide pin to fix the caliper piston
    to the caliper body. Both of the bolts are good. Just the bottom pin won't move.
    Quote Originally Posted by lhurley View Post
    Cheetah Outreach
  10. #8
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    Take the rubber boot off fill with penetrine or some other penetrant and screw the bolt in hit with hammer to get it moving and to pull it out use pliers on the bolt head and lever it out generally once its moving it will come out get some good high temp grease and wet and dry sand paper give it a good rub and greasing don't forget the caliper bracket should be all good
  11. The Following User Says Thank You to 93patrol For This Useful Post:
  12. #9
    38 Post(s)
    Smile
    Thanks mate.
    You just gave me idea of how to use a home made hydraulic press.
    BTW, by caliper bracket, did you mean the sleeve that the pin goes into?
    Quote Originally Posted by 93patrol View Post
    Cheetah Outreach
  13. #10
    Dec 2012
    Bunbury
    Yeah mate that s the one
